Shift Light install on a 93
Yep C1 is the red connector of the four going into the computer. Dont know about the negitive wire on the coil, Shoebox could probably tell you. I would imagine it does though because thats all the MSD boxes use. Try it and let us know
Craig
Craig
there should be only one solid white wire on the dual connector harness that connects to the coil. You can splice into that one. I used a wire nut, but you can also use a scotch lock,(I didnt have the right size).
Jul 4, 2005 05:00 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
