lt1 revving to 7k+
Old Jun 14, 2005 | 10:49 PM
  #46
92rslt1's Avatar
Re: lt1 revving to 7k+
I seriosly doubt anybody hitting 6k with a un-modded computer. i could be wrong so im gonna chime in the expert MADWOLF
Old Jun 14, 2005 | 10:58 PM
  #47
madwolf's Avatar
ABSOLUTELY ALL LT1 and even LT4 F-bodies were limiter right under 5900 from the factory.
The stock tach is off about 300-400 RPM so it may look like 6200 or even 6300 sometimes. If you are not hitting the rev limiter, your PCM is not stock.
Old Jun 14, 2005 | 11:01 PM
  #48
92rslt1's Avatar
Well there it is the facts from a pro.
Old Jun 14, 2005 | 11:09 PM
  #49
93formula's Avatar
thats what i thouht
Old Jun 14, 2005 | 11:14 PM
  #50
easyc4's Avatar
Yes there is supposed to be a rev limiter a 5800, for all the cars. However, my car isn't running to 6200 or even 6300 but straight up to 7 and slightly beyond, then holds there and then shifts. So i think my car must be hitting the end of the fuel map and just holindg there because it cant go any farther. I got so busy at work today that i didn't even ahve time to check the internals yet, but tom. morning i'll check it out and get back to you all.
Old Jun 14, 2005 | 11:16 PM
  #51
93formula's Avatar
then your limiter has been removed
Old Jun 14, 2005 | 11:24 PM
  #52
jchevy's Avatar
You will know if your car gets its fuel cut. Its a kind of a violent feeling.
Old Jun 15, 2005 | 01:02 AM
  #53
FireFox05's Avatar
Will it actually cut it off, or just hold it?
Old Jun 15, 2005 | 01:12 AM
  #54
jchevy's Avatar
Its like a real bad misfire when the fuel is cut. It is extremely unhealthy for the motor.
Aftermarket ignitions cut spark, its much easier on the motor than cutting fuel.
94Form
Feb 10, 2015 11:23 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
91Bird305
Aug 21, 2002 04:38 PM
