lt1 problems
Old Mar 15, 2010 | 08:33 PM
gforce91's Avatar
lt1 problems
i love my camaro but its realy starting to **** me off when i replaced the water pump i also replaced the opti and plug wires and coil. but now it wont start, or it would start but die a couple seconds later. when i try to start it theres a crapload of exhaust and gasoline fumes. and it make a loud noise when i try to start it. i went throug a lot to replace the plug wires and i thing they are ok. so im wondering if its a bad optispark. it worked fine befor i replaced everything except for the distributer was acting up. Has anyone had a similar experience please help.
Old Mar 15, 2010 | 10:48 PM
Need the year of the LT1 engine. Sounds like you may not have aligned the Opti drive shaft correctly if its a 93-94. Not all years of the LT1 are the same.
Why not add a "signature" with basic info about your car - year, model, engine, trans and any major mods. That way people always have the info they need to help you.
Old Mar 15, 2010 | 11:33 PM
gforce91's Avatar
its a 95 lt1. Sorry i dont know how to have a "signature". But ill figure it out
Old Mar 16, 2010 | 05:15 AM
Top of every screen is a red task bar. Left click on "User CP". On the dropdown, left click on "Edit Profile".
If its a 95, and it actually started, its not likely you miss-indexed the Opti by putting the dowel pin in the wrong hole on the back of the Opti. But it is a remote possibility.
Are you sure you have the plug wires on the Opti in the correct order?
What brand is the Opti? Anything other than a Delphi or an MSD is likely to fail.
Old Mar 16, 2010 | 01:53 PM
gforce91's Avatar
the opti is a gm performance replacement and im sure i got the dowel pin in right, i did have some trouble with it thow. But i guess ima chech the plug wire order again. Thanks
InfernalVortex
Jan 17, 2015 09:35 AM
1LEThumper
Jul 14, 2003 12:45 PM
JSK333
Sep 9, 2002 10:33 PM
smacz28
Aug 6, 2002 01:51 PM
