lt1 no spark
lt1 no spark
hey guys i have a 95 lt1 camaro and it has no spark it has a new optispark a new coil and it is getting fuel to the rails and correct psi but has no spark i replaced the ignition lock a couple months back but to bypass the security i just press the wires to the old key while the new key is in the ignition it turns over but wont start wont even try but if i put some starting fluid into it it will try to start but wont and to say again it has fuel it is not a fuel problem how can i figure out whats wrong because i cant throw money at it anymore. Any ideas?
Re: lt1 no spark
Is there any particular reason you didn’t follow up with your previous thread?
https://www.camaroz28.com/forums/lt1...-start-889497/
No point in starting over, ignoring the help we tried to give you last month.
formula69
Apr 1, 2005 05:56 PM
pHEnomIC
Aug 30, 2004 05:23 PM
JoFerZ
Feb 10, 2003 11:24 PM
