Modifying spark plug socket for lt1 spark plug change
Old Aug 29, 2004 | 07:24 PM
pHEnomIC's Avatar
I see on ebay some modified spark plug sockets that are made to fit inside the small areas of my engine. I have a 5/8 in spark plug socket and i was wondering if anyone has a link to guide or can tell me how to make the socket 1 3/8 '' long. Do i just cut it shorter or do i have to modify the inside as well?
Old Aug 29, 2004 | 07:42 PM
Fuels94TA's Avatar
Re: Modifying spark plug socket for lt1 spark plug change
I used a socket that had a 21mm end and cut down the socket down to fit into the tight area of my headers. It was very easy to do with a vice and saws-all. Now I put the socket over the plug and use a open end wrench with a 21mm end and take the plug out.
Old Aug 30, 2004 | 12:19 AM
pHEnomIC's Avatar
Did you have to bore out the inside at all so the porcelein part would fit?
Old Aug 30, 2004 | 12:23 AM
atljar's Avatar
Just get a 1/2 inch drive, 5/8 socket, one of the short ones, not deep.
tack weld a rod, or an old wrench to it. The plug will fit through the 1/2 drive, and its super shallow to fit in all sorts of places.
Old Aug 30, 2004 | 09:17 AM
Fuels94TA's Avatar
I did have to drill the hole bigger for the porcelein to fit.
Old Aug 30, 2004 | 09:57 AM
stereomandan's Avatar
Yes, cut the end shorter on the part that slides over the plug, and then you need to drill out the hole in the back. (at least I had to.) Then just use an open end or closed end wrench on the socket to tighten/loosen the plug. Works well.
Dan
Old Aug 30, 2004 | 05:23 PM
12SCNDZ's Avatar
Hmmm...I used a regular Craftsman plug socket on all 8 of mine Friday. Took me an hour to change 'em...With the MAC headers.
Frank
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
gh0st
Sep 1, 2002 10:24 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
