LT1 Crankshaft sensor. Reality is????
Old Feb 9, 2011 | 02:13 AM
1996camaroZ's Avatar
Conflicting information all over the web.
1996 LT1.
Some say the sensor does not really matter and the car will run with or without it. it only is there to allow the PCM know of a missfire. Nothing more.
Others say it is 100 percent crucial and the car will not run one at all without it.
So the reality of it is???
Old Feb 9, 2011 | 02:45 AM
chevy_dude97's Avatar
Re: LT1 Crankshaft sensor. Reality is????
wont run.
Old Feb 9, 2011 | 05:22 AM
Think about it this way..... the crank sensor is only used on 96/97 LT1's. Yet all the LT1's.... 93-97 run. Numerous people have deleted the CKP sensor from the OBD-II cars, and they run just fine. The PCM only needs the cam position data from the optical cam position sensor in the Optispark distributor. It uses that data to set ignition and injector timing. Does not need CKP data.
And I see the problem.... two responses = one yes and one no.
Old Feb 9, 2011 | 05:48 AM
RamAir95TA's Avatar
Fred is spot-on. Deleting the CKP (or modifying the circuit in any way) will NOT cause a no-start condition, so chevy_dude97 is incorrect.
Old Feb 9, 2011 | 06:50 AM
moparman's Avatar
The CKP is there to detect misfires. It's not necessary, but can come in handy to identify a missfiring cylinder.
Old Feb 9, 2011 | 07:48 AM
However, you provided the correct response.
Old Feb 9, 2011 | 01:35 PM
what was the sensor that will make it not run then? cam right?
Old Feb 9, 2011 | 02:46 PM
Cam and crank position are determined by the opti. Both are internal to it's optical pickup. There is no explicitly named sensor that is used. No low resolution pulse from the opti means the engine will not run.
Old Feb 9, 2011 | 05:53 PM
well that is somthing good to know, I had a 99 jeep grand cherokee that the crank position sensor went out on and would not run. after reading up on the opti this makes a crap ton of sense. Thanks for settin me strait
Old Feb 9, 2011 | 06:35 PM
An LT1 is not like other engines that use a crank sensor in the traditional sense.
D1SC383LT4
Jan 26, 2015 01:41 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Injuneer
Dec 15, 2014 09:36 AM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
