LT1 crank question
Old Jul 13, 2005 | 02:20 PM
Zaddiction27's Avatar
LT1 crank question
I asked this in the lt1 tech forum but to no avail
what are the hp ratings for the following cranks:
cast 3.48
4130 steel 3.48
4340 steel 3.48
just wondering because hopefully I will be able to start my 355 soon and I need to know if I will need a certain crank to handle a blower and nos
Old Jul 13, 2005 | 08:39 PM
Josh-'04 GTO's Avatar
Re: LT1 crank question
Each part manufacturor would probably have a "HP rating" for their own parts, so I would check with the them directly rather than just assign a blanket rating for a particular grade of steel...
To be frank, I would rule out anything but a non-twist 4340 forging for a crank going into a dual power adder engine.
Old Jul 13, 2005 | 09:32 PM
thank you for the reply, so the 4340 eagle crank from jegs should be fine right?
Old Jul 13, 2005 | 09:39 PM
MachinistOne's Avatar
I don't like eagle products, every single crank we have gotten from them has been out of spec. Scat's are better, but still, with motor like that I would only trust a callies crank for that price range.
Old Jul 13, 2005 | 10:06 PM
ulakovic22's Avatar
I agree, if you are going with dual power adders you need to be serious about your bottom end. I would say Callies or Cola.
Old Jul 13, 2005 | 10:45 PM
You didn't get an answer because there is no answer to the question you asked. The first response you got here explained it pretty well.
As a general rule, if it has "LT1" in the topic, it belongs on "LT1 Engine Tech".
Old Jul 14, 2005 | 04:44 PM
SStrokerAce's Avatar
I would have to say I'm happiest with Scat cranks. The Callies I have used measure out perfect but I have to get more sets of bearings to get the main clearances right, which makes me pissed... buying one set of X bearings to get the rear main clearance right. Eagle doesn't do bad stuff for the money, it's still stronger than the block. Either way you have to keep an eye on the clearances anyways.
Bret
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Noenav
Dec 6, 2014 07:35 PM
1LEThumper
Jul 14, 2003 12:45 PM
