LT1 cooling system and dynos
Old Mar 5, 2009 | 05:40 PM
blue 79 Z/28's Avatar
looking for information on the cooling system for my LT1 build. its a 95 model year setup. my problem is i want to engine dyno the motor to break it in before i install it. but i need to find out which are inlets and outlets on the water pump, and where does the steam line go normally etc so i can adapt it to the dynos inlet/outlet setup. anyone got a diagram or a breakdown of the cooling system components? thanks.
Old Mar 5, 2009 | 10:14 PM
http://shbox.com/1/95-97_hoses.jpg
http://shbox.com/1/heater_hoses.jpg
The steam pipe ends up in the upper part of the radiator.
Old Mar 6, 2009 | 12:01 PM
awesome, thanks a bunch. thats exactly what i needed!
Old Mar 6, 2009 | 12:13 PM
one last question, for the return would it be ok to connect the steam pipe to the heater core return port temporarily on the waterpump for dynoing and blocking off the heater core outlet? or should i just loop it and tie in the steam pipe outlet into it with a T
Old Mar 6, 2009 | 12:43 PM
96capricemgr's Avatar
Don't really need a lot of flow through there, just so long as you do something to provide some flow it should be fine. In a pinch depending on the volume the dyno cooling system hold you could even just restrict the line and run it into a bucket so long as the dyno system can handle loosing some volume.
Old Mar 6, 2009 | 05:03 PM
The steam pipe can return either air or water vapor with the coolant. In the stock plumbing, it ends up back in the radiator, at a connection that is supposed to have a water/vapor separator. If possible, dump the steam pipe back to the dyno's coolant reservoir. You definitley want good flow, because #7 and #8 will tend to run hotter than the other cylinders without the flow. That will affect your dyno tune.
Old Mar 6, 2009 | 05:25 PM
ok, thanks. what about the heater hose inlet and outlet. can i just put a loop in there then?
Old Mar 6, 2009 | 06:20 PM
That would be ok.
Old Mar 6, 2009 | 06:58 PM
thanks again for all the help guys
DirtyDaveW
Dec 1, 2016 05:37 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
