LT1 Catalytic Converter removal
Old Feb 6, 2005 | 09:00 PM
heavymetal96's Avatar
Hello all, new guy here.
Im wondering the consequences of removing the cats off of my 96 Camaro SS. They're bad, and I would really like to spend that kind of money on something else for the car.
thanks for any help.
also, any recommendations on a clutch?[SIZE=2]
__________________
Old Feb 6, 2005 | 09:11 PM
mohawkmike's Avatar
Re: LT1 Catalytic Converter removal
Emissions testing is a problem without cats among various other things. I would turn to SPEC for a clutch they build some very good peices. I use their stage 2 and I love it. Never heard anything bad about them.
Old Feb 6, 2005 | 09:17 PM
y5e06's Avatar
the '96 has o2 sensors post-cats. i.e. you can't just remove the cats w/o computer problems. You'd have to run 02 Sims if you just gut them (~$85).
If you don't race, just go w/ the SLP clutch and pressure plate. its an LT4 PP but uses Lt1 stock disc. Good unit for normal or agressive driving. I have a spec stage4 in my track car. that is one agressive clutch, I would not want that for the street.
md
Old Feb 6, 2005 | 09:38 PM
Zack's Avatar
car will sound like crap with no cats
mine does
Old Feb 7, 2005 | 10:20 PM
blind527's Avatar
how will my LT1 sound with no cats and a hooker cat back system???
i don't have emissions where i live so that isn't a problem.
Old Feb 7, 2005 | 10:24 PM
96camaroz28lt4's Avatar
I have a 96 Camaro and I took off the cats, then replace it with some tubing, it doesn't affect the sound but makes it sound a little better. You won't need sims if you just take it and get the cats tuned out of your ECM and the O2 sensors. I have had all this done, you will have to get someone to pass you though because it will pass the computer test but won't pass the visual. I'd recommend removing them myself. I removed them when I got my headers installed.
Old Feb 7, 2005 | 10:29 PM
I burn rice too's Avatar
Your car is going to sound a little raspier without the cat. I had a single cat car with a gutted cat and it doesn't sound as good as the one with the cat. But that was gutted, not swapped for an off road Y pipe. Should sound better with an off road Y. Oh, these cars both run Hooker cat backs.
Old Feb 8, 2005 | 12:39 AM
I don't have emissions tests to worry about. I can pretty much do whatever.
Old Mar 8, 2005 | 01:11 PM
Jakeav11's Avatar
I have a 94 z28 and my converter is crap could i just remove it and put pipe in place or will i have to do computer stuff too
Old Mar 8, 2005 | 01:38 PM
JD95BIRD's Avatar
I believe obd1 doesn't really care if you have a cat or not. I have a gutted cat on my car and my buddy had just a straight pipe in place of the cat no computer codes thrown on either car. obdII doesn't like them b/c of the after cat o2. You'll be fine replacing the cat with a pipe on a 94.
Josh
Old Mar 8, 2005 | 02:40 PM
Bad64chevelle's Avatar
What you can do, which is what i suggest to do if your area has local emissions stops is gut the cat and place a pipe in it so it looks like theres a cat there however its a straight pipe. I gutted my car and never placed a pipe in it, and its causing me some problems I believe because turbulance in there builds up. It sounds bad from inside the car hearing the whirling sound from the car, however made the car a bit louder. I like the way mine sounds. When i do my headers ill be placing a pipe inside the cat.
Old Mar 8, 2005 | 02:54 PM
DemonZ28LT1's Avatar
This is what you need to do regardless if you have emissions or not.
Old Dec 19, 2010 | 12:12 AM
Nyt_Muves's Avatar
So I am looking to do this on my swap as well. I have the drivetrain out of a 94 LT1 TA, and do not want the cats as I have no room under the 83 RX7 that is recieving the new engine. I would also like to delete the EGR system as I see no need for it. I am emissions exempt with this car so no worries there. And I cannot help but believe that the setup will still be cleaner than the filthy little rotary with carb setup that is being replaced. I know for a fact that it will greatly improve fuel economy. Any thoughts or tips for me? I am also planning a cam and a valvetrain freshining.
Old Dec 19, 2010 | 07:39 AM
For starters, the 94 only had a single cat, at the end of the Y-pipe. Unlike the 96 discussed above, the 94 is OBD-I and does not have an after-cat O2 sensor to check for the presence/efficiency of the cat. So you can remove the cat with no consequences whatsoever.
Old Dec 21, 2010 | 02:40 AM
Nyt_Muves's Avatar
Thanks.
DirtyDaveW
Dec 1, 2016 05:37 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
smacz28
Aug 6, 2002 01:51 PM
