LT1 Canfield Heads arrive...
Old Oct 29, 2009 | 01:25 PM
  #46
reamo04's Avatar
i agree, use the 1074's
Old Oct 29, 2009 | 08:17 PM
  #47
unfaded's Avatar
im running these https://www.camaroz28.com/forums/sho...d.php?t=704378 they up the compression a bit although.
Old Jun 30, 2010 | 06:36 PM
  #48
DirtyDaveW's Avatar
I haven't updated this thread in awhile....
I've been driving around with the heads on the car and so far so good. I can't measure the performance yet (went to the strip but it was closed to the non-pro's) but I'm hoping that it will perform well.
I have been battling a lot with getting the heads, gaskets, rockers, guideplates, valve covers, lifters, etc but I'm at least able to enjoy the car now. I wish I'd gotten the heads CC'd while they were off. I may pull one of them just to get it CC'd. The car has a somewhat weak idle right now and I'm not sure what that's about. I'll put Data Master on it this weekend to see what's going on with the TPS, IAC counts, etc. I've got -16 on the MAP reading at idle. The wide band says things are everywhere from 14.5 on cold idle to 17.x at warm. This is a MAF tune. I got some Wide band readings going well into boost (12.x psi) and the A/F ratio was in the 12's. I pulled the plugs and they all look fine/alike.
Old Jul 1, 2010 | 07:20 AM
  #49
RealQuick's Avatar
Dave, if you have the time, try and get back to the track next weekend!
Old May 10, 2012 | 10:57 PM
  #50
DirtyDaveW's Avatar
Re: LT1 Canfield Heads arrive...
I pulled the Canfields (after buying some heavily Lloyd Elliot ported TFS 23 degree Heads) and had the Canfields CC'd. 62cc... that's the reason my torque felt softer than the original 54cc Ported LT1 heads.
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
