took heater hose off, Need help
Old May 9, 2012 | 02:29 PM
lildemars09's Avatar
Alright so my hose that connects to the bottom of my water pump some how blew up, so I decided to just remove my heater hoses because I do not need heat in my car since I am not going to drive it a lot (ill just pack a few blankets ) So what i need now is when I did my TB coolant bypass I linked both lines together that came off the TB. Well now since I took my heater coolant lines off I have one problem, the "T" hose with the bleeder valve connected to the by pass line and that line goes to the big hose that's on the right side of the car (standing in front of car).
So my question is where do I route the little hose that's connected to the big hose on the right side of the motor? (again standing in front of car)
Old May 9, 2012 | 04:21 PM
Re: took heater hose off, Need help
Replace that hose with the 95-97 version that does not have the tee and little hose coming off of it.
Old May 10, 2012 | 12:08 AM
I took the T hose out but the hose that connects to the T hose is the one I dont know what to do with. Its the hose that splits off of the bigger hose on the right hand side if looking at motor, its splits off into a V
Old May 10, 2012 | 06:27 AM
Take pictures or use the hose diagrams on my website to describe what you are referring to.
Old May 10, 2012 | 07:24 AM
http://shbox.com/1/93-94_hoses.jpg (hose #14) The little hose connected to the left side of water pump.
http://shbox.com/1/heater_hoses_93-94.jpg (I have heater hose #9 and #14 connect together right now)
Now I need to reroute heater hose #14 somewhere.
Old May 10, 2012 | 02:48 PM
Like I said earlier, get the 95+ hose #14 (has no tee) and then just cap off the heater hose.
Old May 11, 2012 | 08:45 AM
Alright cool thanks
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
