lt1 block cast numbers is v1206yss is it a ss motor
Old May 1, 2005 | 09:39 AM
lt1srule's Avatar
i bought a 1996 lt1 motor and the cast number is v1206yss does this mean it came out of the 96 ss camaro cant find block cast site for 1996 lt1s
Old May 1, 2005 | 10:20 AM
Dave89IROC's Avatar
Re: lt1 block cast numbers is v1206yss is it a ss motor
I never saw a casting # that had letters
you should have a casting # on the block behind the head, It will most likely be 10125327, which all LT1's and LT4's I've seen are
if it is 10168588 you got screwed, since this is for the L99
Old May 1, 2005 | 10:24 AM
94zgreenmachine's Avatar
I do believe that ALL LT1 and LT4 motors have the same casting numbers. Look for a big 327 cast into the block. Easiest way to determine what it is as lot of people automatically assume it is a "327" engine.
2 bolt and 4 bolt blocks have no distinction between casting numbers either.
Old May 1, 2005 | 12:54 PM
lt1srule's Avatar
this cast is on front of block i aready know its a lt1 the cast at back of block shows 5.7 aluminum heads .but the front cast that is stamped has ss at the end .it is a 96 motor also has a plug under timing chan cover that my 95 lt1 motor did not have like a oil temp plug.
Old May 1, 2005 | 02:53 PM
96capricemgr's Avatar
I think their point was more that the blocks are all the same reguardless or year or what they were put in. The crank position sensor is that plug you speak of and in in the timing cover and no bearing on the block. You should know the wonderful SS got the same entire bottomend as a lowely Roadmaster or worse yet a civilian Caprice. So who cares what it was installed in, in reality if anything I think an SS motor should be avoided as it will have lived a harder life.
Old May 1, 2005 | 04:51 PM
BLinindoll's Avatar
I actually saw the numbers he is talking about on an LT1 engine sitting on a shelf at my school. Started with a V, then some numbers. Who knows what it is. I tried looking it up with the programs at school, but came up with nothing.
Old Feb 20, 2021 | 12:19 PM
Ron Thomas's Avatar
On the front passenger side of the block there is a milled off area with the following letters and numbers...VO425YSH stamped in. The guy I bought it from said it came out of a 1996 Impala SS It also has.iron heads. My question is: was he correct about what the engine came out of?
Last edited by Ron Thomas; Feb 21, 2021 at 09:12 AM. Reason: The "C" is actually an "O"
Old Feb 20, 2021 | 01:51 PM
GM engine identification codes generally follow the form:
First position is engine plant, V = Flint, MI
Second and third position is month of production, always numerical. Is it possible “C” is actually a “0”? 04 = April
Fourth and fifth positions are day of production, 25 = 25th of April
The last three positions (can be LPH a or numeric) code to the engine details like displacement, HP, year/make of vehicle, transmission, fuel system, etc.
Finding the translation of the last three characters is the challenge. And that’s where I run out of the ability to help.
Iron heads were only used on the B-Body..... Impala, Roadmaster, Fleetwood
https://itstillruns.com/decode-gm-en...k-7517566.html
http://shbox.com/1/vin_engine_id.jpg
Old Feb 21, 2021 | 08:33 AM
Ron Thomas's Avatar
Thanks injuneer, I'll start working on the last three letters (YSH) and see if I can learn more. PS, I know what you mean about New Jersey, I left there at 18 and never regretted it. Both my brothers left at 18 also and then my parents at age 65.
Old Feb 21, 2021 | 09:47 AM
I've seen various 3-character codes used on the emissions label. Not sure if those are related. I have a Chilton's for the 3rd and early 4th Gen Camaro/Firebird, and it has emissions routing diagrams for those 3-character codes. I'll look in the F-Body factory service manuals too.
There is an engine partial VIN stamped on the back of the block, near the oil filter. The first number differentiates between the Chevrolet and the Pontiac for the F-Body. Not sure if other brands would have a different first number (3rd digit of VIN).
http://shbox.com/1/block_vin.jpg
Old Feb 25, 2021 | 02:19 AM
sbs's Avatar
sbs
Originally Posted by Ron Thomas
VO425YSH
YSK = 96 Impala
https://books.google.com/books?id=eT...%20lt1&f=false
BIGCOWL-IMP
Advanced Tech
Jun 30, 2019 10:59 AM
averietyson
Apr 20, 2015 01:58 PM
a4z28
Apr 4, 2009 05:57 PM
tfalconier
May 24, 2007 05:21 PM
ss#1230
Parts Wanted
Jan 7, 2005 04:36 AM
