Lt1 block difference ??
Old Jun 28, 2019 | 04:12 PM
BIGCOWL-IMP's Avatar
I sold a 96 Impala motor to a guy with a 94 z28 and he called and said the block is different and the motor mounts don't work......
Either he don't have a Lt1 or i sold him a L99 motor.....maybe ??? I took the motor out of a 96 impala but maybe someone switch it ???............Is that even possible ??.Naaa.....no one would put a L99 motor in a impala.........He said the bolt holes are different on the block....Maybe he don't have a true z28 ???.......Heres the vin just incase some one can tell me if its a true 94 z28.???............... 2g1Fp22p1r2201938
Old Jun 28, 2019 | 04:17 PM
Re: Lt1 block difference ??
If he has a 94 Lt1 motor then what should the numbers be on the block and where are the numbers ?? If someone had i link or something that would be great..
Old Jun 28, 2019 | 04:24 PM
If the motor i sold him is a 96 lt1 motor and not a L99 how can i tell the difference ??? I know they sure look the same.....
Old Jun 29, 2019 | 12:03 AM
The 350ci LT1 block has “327” (last 3 digits of the GM casting # 10125327) in several locations, including front, under the driver side head, near the bottom of the block..
The 265ci L99 block has “4.3” cast on the side of the block. Casting # is 10168588.
Old Jun 29, 2019 | 12:08 AM
On the Camaro, the 8th digit of the VIN is the engine code. V8/LT1 is “P”, so that checks out.
Old Jun 30, 2019 | 09:34 AM
I went to the guys house and he lied to me........said he tried the f-body motor mounts on the other block but would not fit...That was a lie.........when i got there i seen what was going on so i took his f-body motor mounts and bolted them on the block i sold him and everything worked...........he never took them off his block and tried them on the other block...
Old Jun 30, 2019 | 10:59 AM
Good. There's no diff on the mount provisions on LT1 blocks. When we built the stroker, I bought a used block from a yard in Tennessee. My shop said they were pretty sure it came out of a B-Body. Bolted right up.
lt1srule
Feb 25, 2021 02:19 AM
shawngamblez28
Dec 28, 2011 10:34 AM
Brad.S Camaro
Parts Wanted
Jan 21, 2010 07:09 AM
ss#1230
Parts Wanted
Jan 7, 2005 04:36 AM
R1 Casper
West South Central
Jul 31, 2003 09:54 AM
