Lt1 block ?s
Old Apr 3, 2009 | 11:44 PM
a4z28's Avatar
Lt1 block ?s
I bought a spare motor from a friend 100 bucks and was looking to make it a 383 stroker. My question is are there any differences between a Impala ss block and a camaro block. I dont know what year it is somewhere between 94-96 it doesnt have the opti on it so i can tell if it is vented or not. Just want to know if the blocks are the same cause i will use my oil pan, timing cover, and heads from my 95 z. Motor only has 65,000 miles. Thanks for the help.
Old Apr 3, 2009 | 11:49 PM
ak95ta's Avatar
93-97 are the same. Corvettes and some Camaros came with the 4 bolt mains. There was the baby LT1, the l99, which was a 4.3L, and it came in the caprice, roadmaster, ect.
Old Apr 4, 2009 | 06:36 AM
You can determine the year of the block from the VIN derivitive on the back of the block. They are all the same, except for the previoulsy mentioned 4-bolt configuration on the Corvettes - which is preferred. The 350 blocks all have "327" (last 3 digits of the casting #) cast into them in several locations. The L99 block does not.
Courtesy of Shoebox:
http://shbox.com/1/block_vin.jpg
Old Apr 4, 2009 | 07:29 AM
96capricemgr's Avatar
Just to make it a little clearer. There is only ONE LT1/LT4 block casting.
By the time 4-bolt is necessary you need aftermarket caps so I would not worry about finding a factory 4-bolt.
The 4.3L L99 ONLY came in Caprice sedans as the base engine.
Old Apr 4, 2009 | 05:57 PM
a4z28's Avatar
Thanks for the help guys.
D1SC383LT4
Jan 1, 2016 01:56 PM
willismoons
Feb 14, 2015 08:42 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
squinn
Aug 4, 2002 01:06 PM
