LS1 rearend in a LT1?
My brother is getting a new rearend for his 95 Z28 6speed and the donor car is a 2002 Firehawk 6 speed....what all if any modification will need to be done? I know it's a direct swap but I need to know about the ABS sensors brake lines...ect and what not! Thanks fellas!
I have a rearend out of a 01 WS6 in my 94 Z28. It is pretty simple, just pull the axles and put on your caliper mounts then slip the axles back in. I know the sensor on my rearend and the new one I have were different. The 94 rear had a hole the sensor went in and the 01 just has a flat spot the the sensor sits on. So now I dont have ABS.
Ok so basically if the car doesn't have traction control (my brother's Z doesn't either) it should be ok! Also in that thread some were saying you need to swap the axles and some said you didn't...what's the deal on that?
Originally posted by My Red 93Z-28
Is there any benefit in switching to a rear-end out of an LS1 car??
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
