ASP Pulley Squeek!!!
Old Jun 30, 2004 | 02:02 AM
BlackBird97's Avatar
Angry ASP Pulley Squeek!!!
I just threw on a set of the ASP pulleys. Work great except for the fact that when ever my car shifts gears, or I rev it up. It makes this ungodly loud peircing noise. Like the belt is slipping! I just replaced my belt tensioner, still makes the noise. I used belt dressing...kinda went away..wasn't as loud...but then the next day it comes back. What the hell is wrong with the pulleys! Anybody have any ideas? A bad belt perhaps?
Old Jun 30, 2004 | 01:26 PM
Anybody?
Old Jun 30, 2004 | 01:55 PM
Type_O_Negative_1320's Avatar
You could try another belt...it sounds like that one may be slipping (or your alternator, or PS pump, or AC pump may be seizing up). However, even with a new belt, mine has always made the chirping sound on WOT 1-2 shifts.
Old Jun 30, 2004 | 02:47 PM
krispy's Avatar
you can hear your belt assembly over your exhaust at WOT? you need a louder exhaust in that case
Try a new belt, the belt dressing will work as long as you keep applying it but its only a temp. thing.
Old Jun 30, 2004 | 02:54 PM
944v8inDFW's Avatar
Did you replace the belt with shorter one?
With power pulleys and some aftermarket ones you need a shorter belt. Smaller dia. = shorter belt
Old Jul 1, 2004 | 01:42 PM
It came with a belt, it seemed a little stiff though....think thats the prob?
Old Jul 1, 2004 | 01:43 PM
NoFear95's Avatar
I've got the Pulley balancer only and I've had no problem with the belt. Got the part # for the belt at home if your interested?
Old Jul 1, 2004 | 01:55 PM
944v8inDFW's Avatar
Basically, and this is me because i deal with a transplant, I get under the car, jackstands for safety and whatnot, get a breaker bar with a 13 mm socket, make a mark with a sharpie on the tensioner portion that moves and the part that dont, take off the belt and see how far it moves. If it is under about a 1/4 of an inch think about a shorter belt. I like to put the tensionier in the middle of the travel figure out the length from there.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Black Sunshine/ 00SS
Aug 26, 2002 09:26 PM
