Low oil
Old May 5, 2011 | 08:52 AM
andresz28's Avatar
Low oil
I recently changed the oil on my 95 z28 but noticed that the low oil turned on but checked the oil and its fine wanting to know if any one has had this problem before
Old May 5, 2011 | 09:28 AM
Re: Low oil
Have you checked the low oil sensor on the side of the oil pan? If you remove the connector and jumper the two pins of the harness together and the light goes out, then the sensor is likely at fault.
Old May 5, 2011 | 11:55 AM
Re: Low oil
andresz28:
Please post a question only once. After you post it, come back and look at that post to see if anyone has responded. You already posted this question twice before, and people gave you the answer. But apparently you didn't bother to find your old post and look at the responses.
Post a question ONLY once, and ONLY on the correct forum. When you come back, if you can't see your post in the topic listing on the first page, scroll down until you find it. Or use the "search" function by entering your screen name, to get a listing of all your post.
Thanks in advance for your future cooperation.
https://www.camaroz28.com/forums/sho...d.php?t=808126
04-18-2011, 09:15 PM #1
andresz28
oiL light
________________________________________
I just did a full tun up to mu 95 camaro z28 but for come reason I noticed the oil light turns on checked the oil level evrything looks good but stii the lights turns on and on from time to time has anyone expeeriance this beforlet me know any suggestions
You got three responses to that post. But apparently you never took the time to find the post and read them
https://www.camaroz28.com/forums/sho...d.php?t=810659
Yesterday, 02:02 AM #1
andresz28
Low oil
I recently just changed the oil on my 95 camaro z28 but the low oil light came on checked the oil to make sure it was not low and its fine was wondering if any one might know what be causing it anyone know what can be causing that
You got 7 repsonses to that post. But apparently you never took the time to find the post and read them.
HectorM52
Jul 30, 2017 11:46 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
carl.froehlich
Mar 13, 2015 12:38 AM
siguy
Nov 27, 2014 10:07 AM
