oiL light
Old Apr 18, 2011 | 08:15 PM
andresz28's Avatar
oiL light
I just did a full tun up to mu 95 camaro z28 but for come reason I noticed the oil light turns on checked the oil level evrything looks good but stii the lights turns on and on from time to time has anyone expeeriance this beforlet me know any suggestions
Old Apr 18, 2011 | 09:21 PM
my1994z28's Avatar
Re: oiL light
Could be a faulty low oil level sensor on the side of the oil pan,or a broken or loose wire on the plug that goes to the sensor.
Old Apr 19, 2011 | 08:19 AM
Wild Willy's Avatar
Re: oiL light
Are you talking oil pressure warning, or the 'change oil' light?
Old Apr 19, 2011 | 08:45 AM
bw_hunter's Avatar
Re: oiL light
95's don't have an oil life computer and, thus, no 'change oil' ight. All they have are 'check gauges" and "low oil" lights. I assume he means the "low oil" light as any oil pressure warning would be handled by the 'check gauges' light.
If the oil level is OK when checked with the dip stick, then the sensor is bad. The thing is made from plastic and lives in a tough environment.
Be careful when replacing it. Over-torquing it will break it. Not might, will. Replace the seal while you're in there.....
transam_388
Mar 15, 2015 11:53 AM
jj71787
Jan 31, 2015 10:20 PM
Scottylt1
Jan 8, 2015 02:48 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
