lt1 swap in 67 camaro Header choice??
Old May 4, 2011 | 10:57 AM
akeemo's Avatar
Hi All,
Question is, will the year specific long tube headers for my motor (96 lt1) clear everything in the 67 camaro? (the car will be lowered but not insane)
I dont want to use square port headers on the D port heads.
Thank all for any help!!!
Noel
Old May 4, 2011 | 11:59 AM
lt1-xjs's Avatar
Re: lt1 swap in 67 camaro Header choice??
Originally Posted by akeemo
Hi All,
Noel
As long as the square port is bigger than the D port there shouldn't be a problem. I would get headers for a 67 Camaro sbc.
Old May 4, 2011 | 01:45 PM
akeemo's Avatar
yes, this makes sense..
Is this how it is? Are those square ports bigger? and will clear the arc in the D port? If so then not an issue..
Anyone have this experiuence first hand? I dont want to block off the port at all.
Thanks for all help..
Noel
Old May 4, 2011 | 05:57 PM
96capricemgr's Avatar
If worried about blocking the port maybe look for a 1 3/4" primary header, yeah it would be overkill unless the engine is heavily modified but it would ease your mind and should be easy to find.
Old May 5, 2011 | 12:10 AM
97WS6SCharged's Avatar
If you're that worried about it you could call up Kooks and see if they can make a set of headers with D ports.
Old May 5, 2011 | 02:00 PM
akeemo's Avatar
hehehe.... if money wasnt an object i would be getting my hands dirty....
I like the oversized idea though... yea a bit much for my motor... Stock bottom end and heads, just trying to maximize flow, larger TB, 325hp cam spring & rocker set. headers, lightened flywheel..and a good Computer tune. just trying to make a reliable motor run effieciently is all.
Thanks for the responses.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
