Low MPH with Hot Cam, WHY??
Old Nov 14, 2003 | 10:08 AM
  #16
formula383's Avatar
94formulabz, I'm not sure of the altitude but the run was made in Bristol Tennessee at the Bristol Bash.
Old Nov 14, 2003 | 10:19 AM
  #17
Sweetred95ta's Avatar
Hey formula383, thanks for including me in your fast hotcam cars list . Sounds like a strange problem. What rpm is your tranny shifting at? Also, is it a good thing to compare the way a stock lt1 responds to a hotcam, versus a 383? Still the mph is down, I hope you find out what it is. These cars can be such a pain sometimes.
Benji
Old Nov 14, 2003 | 10:43 AM
  #18
Brandon94Z28's Avatar
ya somethings wrong. My 94z ran a 13.0 at 109 on stock heads.
Old Nov 14, 2003 | 11:23 AM
  #19
formula383's Avatar
The tranny shifts at 6300 - 6400. Also, the Z28 is stock bottom end 350. My old car which was a Formula had a 383 in it.
By the Way, Sweetred95TA have you made it back to the track to try for that 10 second pass yet.
Old Nov 14, 2003 | 11:36 AM
  #20
GREGG 97Z's Avatar
I don't have an auto but that shift point sounds pretty high to me. On my best run recently (below) I was shifting at 5900rpm with the hotcam and stock heads. I would think you would see some better times and mph with a lower shift point.
Old Nov 14, 2003 | 11:42 AM
  #21
94 CAMRO Z28's Avatar
According to my stock tach I have best results shifting my hotcam with stock heads at about 6100-6200.
Aaron
Old Nov 14, 2003 | 11:45 AM
  #22
formula383's Avatar
Not sure if that is what it is actually turning but that is what the stock tach shows. I just got Brian at PCMFORLESS to do the program for the car. I will email him and find out what it is suppose to shift at.
Old Nov 14, 2003 | 11:55 AM
  #23
formula383's Avatar
Wow that was a quick reply after 3 minutes Brian emailed me back and the car is programmed to shift at 6000-6100.
Old Nov 15, 2003 | 12:47 AM
  #24
I never got back to the track. The weather got too $hitty and the track kept closing. Looks like I'll have to wait til next year.
Benji
Old Nov 15, 2003 | 01:00 AM
  #25
formula383's Avatar
Yeah I understand what you mean about the weather, the track here is open until the first week of December but I doubt I will get to go back this year.
I would like to give it one more try in cooler weather, at at the track I normally run at. I got a 12.7 @ 107 at Bristol and the track I normally run at is usually around 2 tenths quicker.
if you wait until next year we will probably be trying for that quick pass around the same time. I will be adding nitrous this winter and will be ready to go when racing season comes back around.
Old Nov 15, 2003 | 01:07 AM
  #26
Smokn '94 Z's Avatar
94 CAMRO Z28 the car ran 13.5 @ 100 before the head and cam change. Only had CAI, edelbrock shorty headers and 3.73 gears.
97WS6SCharged on the 12.7 run my 60' was a 1.76 on Nittos, have pulled a 1.69 thoughand got the obd1 high stall problem.
GREGG 97Z, I just posted the bigger mods on my sig, here are the others: K&N CAI, Trick Flow Elbow, MSD6A, Taylor OTVC Wires, Autolite 104's,
I still have stock tb, injectors, maf (not even ported ends)
Also, I just had my trans rebuilt a few months ago, all parts from Art Carr, so I don't think it is slipping, not yet anyway.
FastWhiteTA, I think the mph is low, I am of course comparing it to some of the faster hot cam cars on here, Ken95Z28 (not hot cam anymore though), Sweetred95ta, etc...
I thought someone might know something that may be causing me some issues.
Here is the entire slip to see if you think there is a drop and any certain range.
60ft. 1.76
330ft. 5.208
1/8 8.110
1/8 mph 83.87
1000ft 10.64
1/4 12.777
1/4 mph 107.02
What kind of tire you running? Your #'s are pretty reasonable. With basically the same major mods that you have I ran 12.30 @ 110.34 mph on a 1.64 60'. That was with a Vig3200 Hot Cam & 3.73s on stock heads. However that was on a very cold day with a very low DA. I averaged 12.30 - 12.40 with consistant 1.64 60' on warmer days but only averaged around 108 - 109 mph. So I really don't see a problem with your times or mph. You do need to get that 60' into the sub 1.6's. It can & should. Stall that converter up until you start pushing through your brakes. It will hit nice & hard. I too have wondered why some similar cars with similar mods are running better times then me but then I see all the others with similar mods running a lot slower than me too. I just assume that I have an average performing LT1. No freek for me like most.
Good Luck
Old Nov 15, 2003 | 01:19 AM
  #27
lt1camaroman93's Avatar
what does the car weight.. that can play a part
Old Nov 15, 2003 | 01:24 AM
  #28
formula383's Avatar
All of my passes were made on Nitto's 275/40/17's
I have pulled a 1.69 but then it wouldn't shift out of 1st.
The more that reply to this I might not have a problem, maybe I was just thinking that because I was comparing it to some of the freak HOT CAM cars. I would be very happy if I could get the car down to low 12's on motor. I guess I will just have to try some different things to get it there.
So so you think a dyno tune by Carolina Auto Masters would be worth it over my pcmforless tune?
Old Nov 15, 2003 | 01:27 AM
  #29
formula383's Avatar
The car is full weight with the exception of the spare and jack being removed.
Old Nov 15, 2003 | 05:33 AM
  #30
Arrow
My car is 3600# with driver on those passes. A dyno tune is always an honest way to go....
