Loud pop then fuel fire?
Old Nov 19, 2013 | 06:40 PM
96zee's Avatar
So I was just backing out of my driveway to get gas after a trip to the dmv. I heard a loud pop and tons of smoke was pouring out, popped the hood and there was a small fire. Where this happened I saw pieces of black plastic shattered and what looks like half of a black plastic clamp. Before this I could smell raw gas badly. I figured it was the egr. The engine still has power so I'm wondering what could have caused that. No major damage was done just some burnt plastics. The fuel line was burnt to a crisp and disconnected. Any information you need please let me know I would like to figure this out. Still in shock haha.
Old Nov 19, 2013 | 07:05 PM
96zee's Avatar
Re: Loud pop then fuel fire?
Found a green connector end on the passenger side in pieces, don't know what it's for.
Old Nov 19, 2013 | 07:23 PM
96zee's Avatar
After some more digging I found my egr valve is not bad, the mechanic did not plug it back in and I believe he capped off the vacuum connection. Could someone post a picture of the egr valve connections I cannot see diagrams clearly online.
Old Nov 19, 2013 | 09:57 PM
http://shbox.com/1/egr1.jpg
Nothing to do with EGR should cause a fire or gas smell. It's all exhaust gases.
Old Nov 20, 2013 | 08:34 AM
The green plug on the passenger side is likely the connector for the MAP sensor. I suspect you had a fuel accumulation in the intake manifold (leaking fuel pressure regulator??) and it exploded, and blew the black plastic MAP sensor out of the manifold.
Not sure what we would do without Shoebox's photos:
http://shbox.com/1/harness1.jpg
http://shbox.com/1/map.jpg
Old Nov 20, 2013 | 07:03 PM
96zee's Avatar
Thanks injuneer i appreciate all of your help on my other threads. That seems to be what happened! I was messing with the fuel pressure regulator the other day, thinking it was the egr...duh. This mess has taught me a lot about my car though. Found my exhaust leak to! Thanks to the 5lb bag of baking soda I dumped on the fire lol. Now to take on the egr issue! Need to find pictures of all the components and plugins for it.
Old Nov 20, 2013 | 08:43 PM
With that much energy dissipated you need to check everything attached to the intake, including parts connected by hoses. MAF, throttle blades, Opti vent line fittings, vacuum lines, etc. I've had a nitrous pop bend the throttles blades to a 90° angle. And it didn't blow the MAP sensor off.
Old Nov 20, 2013 | 08:55 PM
96zee's Avatar
With that much energy dissipated you need to check everything attached to the intake, including parts connected by hoses. MAF, throttle blades, Opti vent line fittings, vacuum lines, etc. I've had a nitrous pop bend the throttles blades to a 90%u00B0 angle. And it didn't blow the MAP sensor off.
Ok I will definitely do that tomorrow after work! Thanks again!
Ps: I think it's ironic how i said I was going to set it on fire not to long ago... And sure enough. Had I been on the road it would be a crispy camaro.
grabbem88
Mar 18, 2015 01:25 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
nophix
Nov 30, 2014 10:26 PM
