Lost oil pressure while datalogging
Old May 15, 2005 | 04:12 PM
wicked_95z's Avatar
Guys I need to know what to check other than bearings. What else would cause a pressure loss. Im not talking about no pressure at all. I was making a couple of WOT blasts to get some data and I let out of it and shifted into 6th and was cruising. I got up to my turn and went to push in the clutch and felt grinding through the pedal. I made my turn with the clutch in and it stalled on me. Wouldn't restart so I popped the clutch and it started; but I saw that I had no pressure so I shut it back off.
This is what I know right now. There is the normal oil level in the pan and until this my pressure was great, 15-20 psi at idle. Motor has about 10-15k miles on the latest stroker. The oil pickup was tacked on when installing so Im pretty sure it didnt fall off. My first thought would be to check the oil pump driveshaft. But I dont think I'm that lucky
Old May 15, 2005 | 05:02 PM
wicked_95z's Avatar
Re: Lost oil pressure while datalogging
Well I just restrated the engine and I had oil pressure but it was very low, just above the red mark and the engine sounded horrible. Sounded like loose bolts rattling around.
Old May 15, 2005 | 07:17 PM
FastZinTennessee's Avatar
Get a big funnel, and put a coffee filter in it. Then drain the oil through that. See if there is any metal glitter in it. If so, you know it's a bearing somewhere.
Old May 15, 2005 | 07:19 PM
Dave89IROC's Avatar
I'm thinking cam bearing, though it might be a main as well, problably not a rod bearing if its not knocking
Old May 15, 2005 | 08:43 PM
ssbowtie1's Avatar
Car turns off + barely turns back on + running like crap + sounds like loose bolts rattling around = spun crank, cam, or rod bearings.
Sorry
Old May 16, 2005 | 03:46 PM
wicked_95z's Avatar
Yeah I got that sick feeling in my stomach when it happened so I figured as much. I'll check the oil this weekend and see what's that tells me.
HectorM52
Jul 30, 2017 11:46 AM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
