Loose header bolt = stumble
Old Jun 10, 2008 | 09:09 PM
oneqwkfbody's Avatar
trying to track down this low end stumble that seems to clear up past 2-3k rpm. just installed new opti, checked and double checked wires to make sure they were in RIGHT, and plugged in RIGHT...even swapped out coil and IM from my caprice, fresh tank of gas etc etc...still stumbles on the low end...
so i looked at the header bolts, and damn if #8 had backed out, the last one of all!!
didnt get to tighten it yet,,
but heres the questions;.....anyone else have a low end stumble / miss with a loose header bolt...im running mac midlengths....and seems like when my m22 plug fell off the air fitting it kinda did the same thing, cept i dont seem to hear the leak...so much...but the car clears right up after 3k rpm...
i will psot more after i tighten it down and check the rest...car was too hot, and i was too sweaty to try anything else earlier...
thanks for all who were checking ou my other posts!!
wish me luck!
b
Old Jun 11, 2008 | 12:32 AM
TobyZ28's Avatar
Check your spark plugs as well to make sure theyre properly torqued down right.
Old Jun 11, 2008 | 12:03 PM
95Blackhawk's Avatar
One loose header bolt should not cause a stumble.
Old Jun 11, 2008 | 09:56 PM
If its allowing the exhaust to pull (educt) air into the loose header flange, its going to cause a false lean condition, and the PCM will start adding extra fuel to that bank, possibly causing a misfire.
Old Jun 12, 2008 | 05:13 AM
TobyZ28's Avatar
Ive found the A4's to be very sensitive in certain lower RPM/load conditions.. if anything is wrong with anything you start to notice it at the lower RPM
Victor Lamb
Aug 26, 2017 02:52 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
