Looks like there is a problem with the 918's after all
Old Jun 7, 2007 | 10:15 PM
speed_demon24's Avatar
http://www.ls1tech.com/forums/showth...3&page=1&pp=20
Old Jun 7, 2007 | 10:22 PM
RyanD's Avatar
**** i just installed mine
Old Jun 7, 2007 | 11:06 PM
jasonisdn's Avatar
glad AI used the 26120's on my heads. hope everyone gets the issue taken care of without to much trouble.
Old Jun 7, 2007 | 11:36 PM
thesoundandthefury's Avatar
Does anybody know if Comp Cams has outsourced the production of their Pacalloy springs to overseas as well?
Old Jun 8, 2007 | 12:56 AM
I know they switched suppliers, so it wouldn't supprise me if they did.
Old Jun 8, 2007 | 01:06 AM
sbs's Avatar
sbs
Couple more:
http://www.cheersandgears.com/forums...howtopic=17259
http://forums.corvetteforum.com/show....php?t=1715377
http://www.ls1gto.com/forums/showthread.php?t=159887
Old Jun 8, 2007 | 02:38 AM
Heatmaker's Avatar
Advanced Member
Theres no hard proof in thos links just urban legends. Who knows if those springs were installed properly, or if they were a match for the components being used. 918's are popular and used in allot of applicaitons. For them to break on a few people I wouldn't be surprused. Who knows how these guys are running thier cars. And where is the proof of comp switching suppliers etc etc. Just not enough hard evidence.
Old Jun 8, 2007 | 02:48 AM
sbs's Avatar
sbs
Didn't read any of the threads you're commenting on, didya?
Old Jun 8, 2007 | 03:18 AM
I guess the fact that reports of them breaking started popping up out of nowhere is enough to convince you? Or the fact that Bret and Lloyd no longer use comp 918 springs because of the switch in suppiers? Oh yeah and the set that broke on a set of LE2 heads must have been set up wrong even though Lloyd sets each spring up at the right installed height.
Old Jun 8, 2007 | 03:32 AM
bdc95ta's Avatar
What springs are Bret & Lloyd using on there LE2 & 3 setups now?
-b
Old Jun 8, 2007 | 04:33 AM
rskrause's Avatar
Moderator
I have used a lot of Comp products over the years and am becoming disenchanted. For one thing, their prices are getting out of line with their direct competitors, without any apparent improvement (an maybe a falling off) of quality. But starting to source the stuff outside the US might just push me over the edge. Poltics aside, I recognize it is possible to produce high quality stuff in low wage areas. But you have to have a very careful inspection program, reliable people on site, etc. It is starting to appear that Comp is not doing that. The 918 springs and the HR lifters seem like two major screwups that just should not happen to a big manufacturer charging premium prices.
I think I am going to switch to Crower and Manley for most of my stuff.
Rich
Old Jun 8, 2007 | 06:43 AM
wrd1972's Avatar
I had three break on brand new LE2 heads with less than 20 miles. Lloyd sent me PAC replacements.
Old Jun 8, 2007 | 07:12 AM
Javier97Z28's Avatar
Moderator
Argh, I hope my ~1/2006 918's are gonna hold up..
Old Jun 8, 2007 | 07:33 AM
wrd1972's Avatar
Anyone with Comp 918's better check them ASAP.
A fellow over at ls1tech stated how well his have worked and how people tend to jump to conclusions at the drop of a negative thread.
He mentioned the whole bit about bad spring install and the proper way to drive and avoid WOT till things warm up.
He then started to comment that if springs were going to break that they would tend to break in the middle rather than on the tops like mine did.
Well he started to get nervous since the posts kept coming and stated that he was going to check his beehives immediately. Anyone want to guess what he found? A busted beehive.
Old Jun 8, 2007 | 08:55 AM
OldSStroker's Avatar
-b
Originally Posted by steve9899
I asked Lloyd Elliot about this a couple months ago and he said he switched to PAC Beehives a while back. PAC was the previous manufacturer of the 918s. The problems with the 918 seem to have started after the change of suppliers.
Yes, he changed.
