looks like its the fuel pump
Old May 21, 2006 | 09:12 PM
bringBackCamaro's Avatar
I think i've tracked down my no-start problem.
I bought a fuel pressure gauge at autozone and my car reads
0 psi at key on, and 0 while cranking
I changed the fuel filter and its the same thing,
so i ordered a racetronix pump from thunderracing for $160
Is that $160 kit the only thing i need to change it?
i am going to cut an access hole in the car rather than drop the tank
Old May 21, 2006 | 09:16 PM
stingercamaro's Avatar
Re: looks like its the fuel pump
Have you tried the fuel pump prime connector?
http://shbox.com/1/fuel_pump_prime.jpg
Connect a hot to the connector and see if the pump turns on.
Old May 21, 2006 | 09:32 PM
I have Not tried that,
If i use that primer connection, and the pump turns on, what does that mean?
Old May 21, 2006 | 09:40 PM
It means your pump works, that line is a direct link to your fump, put a hot to the connector, and your juicing the pump.
If it doesn't work, it's a good sign that your pump is dead.
Old May 21, 2006 | 10:12 PM
I did not use head shielding on the fuel lines above the Y pipe for my new headers, but i did bend the closest one out of the way
Is it possible that heat from the new Y pipe heated the return fuel line and caused the pump to fail, or was this unrelated
Old May 21, 2006 | 10:26 PM
How far is are the lines from the pipe? Regardless, I doubt that would cause your pump to fail. Have you run your tank dry?
Did you test the connector?
Old May 21, 2006 | 10:41 PM
It always takes 13 gallons to fill up the car, so I never run it dry
I will have to check the primer connection tomorrow after work, it died at a friends house and its still parked there
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
