A look at my opti and the problem I've been chasing
Old Sep 17, 2009 | 07:59 PM
  #16
Spartan7's Avatar
http://shbox.com/1/pull_pulley.jpg
Don't pull the hub off, you don't have to remove it for an opti change. Just turn it.
Old Sep 18, 2009 | 01:15 AM
  #17
SmokeyBlaZe's Avatar
Yea Thats not like the puller that i rented. heres a pic of what I have, Not sure it will work?
Old Sep 18, 2009 | 05:23 AM
  #18
Guest47904's Avatar
Guest
Did you unbolt the pulley from the hub
Do not remove the hub. You will have problems if you do.
Old Sep 18, 2009 | 02:51 PM
  #19
Spartan7's Avatar
That only works on the 96-97 hubs, which have the extra holes for a 3-bolt puller. Unless you have that style of balancer, you need the claw puller.
Old Sep 18, 2009 | 06:31 PM
  #20
Still trying to find a claw puller.
Old Sep 18, 2009 | 08:39 PM
  #21
johnnyb's Avatar
autozone should have one for rent- thats what I did. Be thankful you dont have the underdrive pulley I have.... nothing fits on it so talk about a nightmare
Old Sep 18, 2009 | 09:22 PM
  #22
I believe I got what I need now, I will find out for sure tomorrow, thanks for the replies. Also Do I have to remove the whole opti to replace the cap & rotor?
Old Sep 19, 2009 | 04:49 AM
  #23
Guest47904's Avatar
Guest
No. Cap and rotor can be done with it on the engine. If it's not leaking, don't take the base off.
You don't need a puller. Take the bolts out of the pulley and tap it with a plastic hammer to get the pulley off the hub.
Old Sep 19, 2009 | 05:06 AM
  #24
does it matter which way the arrow is facing on the pulley? when i take the 3 bolts out it moves about a 1/4 turn
Old Sep 19, 2009 | 07:26 AM
  #25
johnnyb's Avatar
nope, arrow is irrelevant.
Old Sep 19, 2009 | 06:00 PM
  #26
Didnt have enough to swing a plastic hammer :/ The pulley is on there pretty good , tried using the claw puller and its giving me hell trying to tighten the claws and hold them in place at the same time. I need some extra hands.
Old Sep 19, 2009 | 06:16 PM
  #27
Guest47904's Avatar
Guest
So stick something behind the pulley that allows you to hit it and knock the pulley off.
Old Sep 19, 2009 | 06:54 PM
  #28
Tried it, no luck, Ill give it another shot tomorrow, thanks again speedy
Old Sep 20, 2009 | 09:40 AM
  #29
Have you saturated it with a good rust penetrant, like PB Blaster? Rust is the only thing that's holding it on. When the car left the factory, the pulley would fall off when you removed the three bolts that hold it on the hub.
Be careful not to hammer on or pry on the outer ring of the damper/pulley. The damper consists of two metal rings, held together with a hard rubber ring between them. If you damage the rubber ring, the damper/pulley is usesless.
Old Sep 20, 2009 | 10:51 AM
  #30
Just some good ole wd-40, I think today is my lucky day, thanks for the info
