LE2 goin in...couple questions
Old Oct 19, 2007 | 03:06 PM
  #16
Its simple math... to make 450 flywheel HP on the stock injectors, programmed at 24.9 #/HR, and running 43.5psi design fuel pressure, and assuming the injectors would continue to operate correctly at 100% DC, you would have to have a brake specific fuel consumption of 0.44 #/HR/HP. It is possible to reach that BSFC with a good tune, I've done it... but to assume that the injectors will perform correctly at 100% DC, and put your engine at risk doing it is just plain dumb. Pour thousands into an engine, and then play Russian roulette with some 24# injectors......
Old Oct 19, 2007 | 03:16 PM
  #17
JC95Z's Avatar
^wow! I think that clears things up.^
Old Oct 19, 2007 | 03:42 PM
  #18
SS MPSTR's Avatar
For initial start up, the stock stuff isn't going to hurt a thing.
Old Oct 19, 2007 | 03:59 PM
  #19
ulakovic22's Avatar
Get a mail order tune from Ion and some 30lber's. There are some for sale in the Texas section for $175 from Bill. He's a good guy, local to me, and I have bought stuff from him before. I don't see the point of slapping something together half a$$, you're in the home stretch so don't start cutting corners.
Old Oct 19, 2007 | 06:34 PM
  #20
95z28man's Avatar
That's exactly why I made this thread. I don't want to cut corners. I was unsure about my initial startup with a stock tune and injectors because I didn't want to even risk damaging something. I think I will just buy the bigger injectors and send the PCM in for a tune before I even start it just to be on the safe side.
Thanks a lot guys
Old Oct 19, 2007 | 06:58 PM
  #21
ulakovic22's Avatar
You won't damage anything by installing the motor and firing it up, but I don't see the point of putting it together and starting it if you can't drive it and enjoy your hard work. It's like teasing yourself, you have this great motor and car that you really can't drive because you have to ***** foot the gas pedal. Besides even if everything is done and ready to go it will only set you back a week. Ion does core refunds so he can send you one ASAP and you just ship him your old PCM and you get credit. Good luck with everything, be sure to post up a vid when you get it fired up and running!!
Old Oct 19, 2007 | 07:30 PM
  #22
95z28man's Avatar
I agree, I want to be able to enjoy it right away. I had no idea I could have a tuned PCM sent to me immediatly until mine is done. That's a relief. I'll definately post up a vid when it's done, but I can tell you for sure I'll probably be posting quite a few questions before then lol.
Old Oct 19, 2007 | 07:36 PM
  #23
raroz28's Avatar
I sent mine to Ion on Monday and had my pcm by Friday.
mikey4play
Mar 15, 2015 11:45 AM
Bignasty85
Mar 3, 2015 04:05 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
taner
Aug 28, 2002 01:21 PM
