94 Z28 Distrubutor ???
Old Oct 18, 2007 | 12:37 PM
twind's Avatar
hey guys...i'm having prob with my z28....she was running beautifully but then suddenly she began stalling...I hope im using the right term...but basically the car started shifted into reverse....reverse then car died...after this ...car wouldn't start..I took to the mechanic and they said it might possibly be the distributor ...SO HOW DO I CHECK THAT???
Old Oct 18, 2007 | 02:04 PM
Start by scanning the PCM for codes. A failure of the optical sensor will set codes. A failure of the high voltage section (cap & rotor) will not. But there are many other possible cause of a "no start", and the scan might pick those up. A check of the fuel pressure would also be a good idea.
Old Oct 19, 2007 | 07:56 PM
twind's Avatar
ok, I will for sure do that..thanx again every1
Old Oct 19, 2007 | 07:57 PM
twind's Avatar
fuel pressure is fine....it is definitely the distributor
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
