LE2 / BRE Dyno numbers , inside
Old Feb 13, 2006 | 03:49 PM
  #46
RealQuick's Avatar
Re: LE2 / BRE Dyno numbers , inside
Originally Posted by red96z
awesome ! cant wait too see what it does ! its like my car it put down 410 through an auto ....cant wait to see what it turns !
You'll have an ET advantage for sure since you have an auto...definitely post results when you hit the track.
Old Feb 13, 2006 | 04:03 PM
  #47
red96z's Avatar
ya auto and a nice converter !
Old Feb 14, 2006 | 10:06 AM
  #48
METALBEAST's Avatar
Good Lord! Those are some nice torque numbers!
Old Feb 14, 2006 | 10:09 AM
  #49
SStrokerAce's Avatar
I was about to say.... no power down low? peaky dyno charts? I've heard all that BS before but it's kinda hard to say that once you look at the dyno charts. It's hard to say that he doesn't have any power down low with that much TQ and that flat of a TQ curve.
Bret
Old Feb 14, 2006 | 10:43 AM
  #50
RealQuick's Avatar
Bret
I was saying his tq curve is flat as $hit which is awesome and that any car that performs bad down low would be evident on the dyno when looking at the tq curve. I think this particular car will be great down low.
Old Feb 14, 2006 | 12:06 PM
  #51
I was just making a comment towards some guys that are "LE/BRE" negative.... i've heard those comments all before and just wonder where they are founded.
Bret
Old Feb 14, 2006 | 01:17 PM
  #52
Z28Horn's Avatar
Roadtrip, how the hell do you hit 112 mph on a stock cam, and stock heads???? . Granted you have the M6 vs my A4, I'm nowhere near 12 seconds much less 112 mph.
Zach
Old Feb 14, 2006 | 01:52 PM
  #53
sprayedtransam's Avatar
Zach
Light car and a good setup. Ghey driver though
Nice numbers Brady.
Old Feb 14, 2006 | 02:47 PM
  #54
LT4POWR's Avatar
A DYNO QUEEN IS NOT ALWAYS A TRACK QUEEN !
No **** Sherlock. As it’s been addressed MANY times in the stupid “my head ported/cam doctor is better than yours” hijacked threads. ETs are VERY dependant on car setup, driver skill, track conditions, da, etc. As someone (Mindgame, I think) said…“I’ve never seen a head/cam package cut a good 60ft time”
im just saying i have seen cars dyno high and not run the times it should cause its missing power down low !
It also amuses me when people over play the important of low end tq in drag racing. Don’t most drag racers have at least a 3,000+ rpm converter and/or 3.73 gears???
Old Feb 14, 2006 | 03:59 PM
  #55
TireMarx723's Avatar
One question, looks like you ground this cam to spin to 6500, could you gain more torque if you ground the cam if it were only to be spun to 6200 (Like the LE1=6200) or would grinding it for 6200 max rev only move the powerband down? Hope that makes sense. I ask because you said it struggled over 6k rpm
Old Feb 14, 2006 | 05:52 PM
  #56
Kryckter's Avatar
Zach
Alot of bolt-ons....327 RWHP...
Very Very light car and a good track with Good Density Altitude....
And to comment on the dyno cars vs. track times.
I had a LE2 setup on a Trans Am. Dyno'd 417 RWHP.
Ran 11.7 @ 118 at 800 DA. The LE2 setups not only produce dyno numbers but run good times.
My times were run through a 6 spd with 3.73 gears. Auto with a stall, And the times would have been alot faster.
Once again.... Lloyd and Bret setups are unmatched for price and performance.
Old Feb 14, 2006 | 06:33 PM
  #57
Joe you better step up and throw some more mods at that C5.... D-rad has got to be a bit faster now!
Brady's cam was ground for a set of stock heads to start with. The intake lobe is really aggressive, so it's not the easiest thing to run to 6500rpm. You could possibly make more TQ with a smaller cam but it would be hard to do.
Bret
Old Feb 14, 2006 | 07:33 PM
  #58
roadtrip120's Avatar
Bret
Thanks for the awesome setup, i cant wait to try and squeeze some more hp out of this thing. I'll need those ET drags soon.
Zach
Full bolt-on car ,3075 lbs , 1.76 60' ,327hp 350tq..Thats how
Shon's bolt-on car is 300 lbs lighter than mine and he is pulling 1.6 60' I'm sure he is traping in the 114mph ++..
Old Feb 14, 2006 | 08:54 PM
  #59
Shon Herron's Avatar
Congrats! Now go run it and give me a target, LOL!!
Car without driver is in the 28xx range, it has trapped 115.72 but normally in the 112-113 range. with 1.65 60's normally.
Old Feb 21, 2006 | 07:13 AM
  #60
METALBEAST's Avatar
Zach
My friend Betty's car (98 Formula A4 3.23s) with just a couple of boltons (shorty headers, hypertech tune, Nittos and !mufflers) ran 12.7@111.74 on January 28th at SDR in Reynolds, Georgia. Now yes it is an LS1 car, but she is not putting down more than 310ish RWHP. Weight with here in the car is 3300 lbs.
