LE2 / BRE Dyno numbers , inside
Old Feb 12, 2006 | 03:19 PM
  #16
marshall93z's Avatar
Re: LE2 / BRE Dyno numbers , inside
Originally Posted by Steve0
Is this with stock injectors/fuel system?
Read his post!
Old Feb 12, 2006 | 03:38 PM
  #17
Steve0's Avatar
Originally Posted by marshall93z
Read his post!
Whoops! Dont know how I missed that the first time.
Old Feb 12, 2006 | 03:43 PM
  #18
Honda Hunter's Avatar
Those are crazy nice numbers. I just dont understand how the other guy with the 383 LE3 setup (Chris I believe) only made 3 horsepower more. Must be in the tune. Setup was almost the same I think.
Old Feb 12, 2006 | 04:01 PM
  #19
89385formula's Avatar
Chris made 431/415, so thats 14 more HP/21ft lbs more torque, not 3. But it could be in the tune, because his was all tuned, and these numbers are on a mail order tune.
Old Feb 12, 2006 | 04:41 PM
  #20
neil350's Avatar
Awesome glad you got every thing worked out, good luck with it.
Old Feb 12, 2006 | 05:26 PM
  #21
MEAN LT1's Avatar
I thought I was the only person who noticed that as well. It does appear that the the majority of the heads/cam motors make between 375-400+. The strokers have not been impressing me too much as of late. I know it depends on the setup and what people ask for but I expect numbers to be higher for the strokers. At least between 430-450+. But this isn't always the case. Its almost as if someone would be happier going with a heads/cam motor versus a stroker. Yes I do know a well built stroker "should" knock the pants off a .30 overbored motor but from what it looks like its going to be close. Im reffering to HR motors of course. Am I off base with this statement?
Old Feb 12, 2006 | 05:32 PM
  #22
mattbailey's Avatar
Great #'s man. Post up that graph. Where did you make peak hp/tq? Curve?
Old Feb 12, 2006 | 05:43 PM
  #23
Strokers will make more power, but the Intake and stock castings become a restriction. Its very common for the stroker to not make but a few more ponies then the comparable 350-355. Thats the very reason I built a 355.
Old Feb 12, 2006 | 06:07 PM
  #24
96capricemgr's Avatar
Nice, thank you for the mod details, makes it a lot easier to compare setups.
Once you get the pcm fixed and more tuning done a graph would be great.
Old Feb 12, 2006 | 09:09 PM
  #25
roadtrip120's Avatar
Old Feb 12, 2006 | 09:30 PM
  #26
TireMarx723's Avatar
whats the diff between BRE Cam and lloyds cam?
I thought 1.7rr were too much for these cams?
Sick #'s though, please fill me in on the above questions though as I just sent lloyd my heads
Old Feb 12, 2006 | 10:07 PM
  #27
DiabloGT's Avatar
is the bre cam bigger than the le3 cam? whats the specs on it?
Old Feb 12, 2006 | 10:12 PM
  #28
MEAN LT1's Avatar
Bret grinds these cams for Lloyd for the customer. Each cam is speced for the customer.
Old Feb 12, 2006 | 10:23 PM
  #29
TCAL95Z's Avatar
Nice numbers
Do you mind saying approx what the lift is on the BRE cam?
I'm curious how that compares to the LE 1,2 or 3 cam
Old Feb 12, 2006 | 10:26 PM
  #30
So your saying, the BRE cam is actually the LE cam? So is this the LE2 cam? LE3 or LE1?
