Knock sensor bypass for OBDII
Old Dec 11, 2008 | 12:02 PM
texas97z's Avatar
I found the correct resistor to use to bypass the knock sensor for the ODBI but it was followed up with a post saying will not work on OBDII. Does anyone know the correct resistor to do this with? I am not wanting to buy an LT4 KM, I just want to try the resistor out. Thanks for the help.
Old Dec 11, 2008 | 01:18 PM
93k-107k ohms is the resistance range of the OBD-II knock sensor. You better know what you are doing if you are going to bypass it.
Old Dec 11, 2008 | 01:59 PM
texas97z's Avatar
Thanks shoebox. I know the risk of the system not dectecting knock, but this is false knock. Thanks for your warning.
Old Dec 11, 2008 | 11:21 PM
TBSPW's Avatar
whats the worse that can happen anyway...well besides the engine taking a dump....but on a overall stock engine is there much of a downside.
Old Dec 11, 2008 | 11:33 PM
Detonation, leading to cracked ring lands on a brittle stock hypereutectic piston.
Old Dec 11, 2008 | 11:35 PM
TBSPW's Avatar
yeah that never sounds good...i thought of doing the resistor thing but now id much rather just get a lt4 knock sensor
Old Dec 12, 2008 | 12:12 PM
blue 79 Z/28's Avatar
remember the days when cars didn't have knock sensors? lol
Old Dec 12, 2008 | 01:30 PM
Yeah and you could play with the timing all day to get it right.
Old Dec 12, 2008 | 09:45 PM
You want an LT4 knock module... not an LT4 knock sensor. The LT4 used the same knock sensor as all the OBD-II LT1's. Its the little chip/module that goes into the PCM that you swap out with the LT4 knock module. It simply filters out the noise generated by the full roller rockers that were used on the LT4's.
Old Dec 13, 2008 | 02:06 AM
TBSPW's Avatar
thats what i meant....just called it the wrong thing...my bad
Old Dec 13, 2008 | 01:05 PM
Dave1980's Avatar
On top of getting the LT4 module. If you still have problems, and know it is not real knock you can also talk to whoever does your tuning about de sensitizing the knock sensor some. (I have heard they can do that.)
On a side note I remember one guy having problems with the LT4 knock module. I have it, and have not had problems. I have had an exhaust leak, that gave me false knock retard before. I was watching it via LT1 scanmaster.
HectorM52
Jul 30, 2017 11:46 AM
99z28 carguy
May 26, 2015 11:35 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
