Knock Sensor
Old Dec 22, 2006 | 12:33 PM
93 4mula's Avatar
Knock Sensor
Im getting around to installing my 385ci Solid Roller back into the car and I was curious if I really needed to install the knock sensor back in the side of the block since my block is now half filled? Just curious if it would read accuratley or not..
Old Dec 22, 2006 | 01:51 PM
OBE1 95Z28's Avatar
You'll get a SES code and the PCM will pull out timing if the knock sensor circuit is not in place. The system can be disabled with a resistor to ground if you choose not to use the sensor.
Old Dec 22, 2006 | 02:42 PM
Knock sensor will pick up a huge amount of noise from the solid roller cam, and the hard-block will make it that much worse - its going to surround the KS. Leave the KS out and have it tuned out of the PCM.
Old Dec 22, 2006 | 05:48 PM
93 4mula's Avatar
Ok so just get it tuned out of the computer and Ill be ok?
Old Dec 23, 2006 | 08:40 PM
I've been running an 800HP solid roller nitrous motor for 6 years without a knock sensor. Just make sure your tuner knows what he's doing.
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
