Knock Sensor
Knock Sensor
Im getting around to installing my 385ci Solid Roller back into the car and I was curious if I really needed to install the knock sensor back in the side of the block since my block is now half filled? Just curious if it would read accuratley or not..
Knock sensor will pick up a huge amount of noise from the solid roller cam, and the hard-block will make it that much worse - its going to surround the KS. Leave the KS out and have it tuned out of the PCM.
14
Aug 11, 2015 12:03 PM
Noct
Jul 14, 2015 01:18 AM
