Which shaft mounts for Lt1 heads?
Old Dec 23, 2006 | 03:13 PM
T/A lt1's Avatar
Looking at buying a set for GM LT1 castings and wondered what most were using and a part umber would be nice also. LMk later Clint
Old Dec 23, 2006 | 04:04 PM
SStrokerAce's Avatar
I know both Jesel and T&D have them. Jesel PN KSS-336060 will work.
Bret
Old Dec 23, 2006 | 10:54 PM
Projectz28's Avatar
Moderator
I just got me Jesel rockers in yesterday. Started mocking them up tonight to get a pushrod measurement.
I used the KSS-336060 (1.6 ratio I and E). The only problem I have run into is that they dont fit if you are using head studs. The studs stick up way to far to fit under the rocker stand. Jesel includes 8 new head bolts (4 for each side) to be installed. They are a torx head with a slim head to fit under the stand. They also included the torx bits (not just a cheap crappy tool either).
They also include a .100" shim to use if you are running longer valves. Using those its possible the studs would have fit if I machined off the top threads because the rocker stand looks like it cleared the nut. I opted to just pull those studs and install their bolts.
Other than having to pull those studs I havent had any problems. they seem to fit well. I am ordering new 3/8" pushrods tomorrow, but thru my mock ups I dont forsee any more problems. Dont have valve covers to fit yet either but I think I am going to get the Summit brand fabbed covers and drill my own breather. Should not be a problem with those either.
Old Dec 23, 2006 | 11:15 PM
atljar's Avatar
I researched this extensively when I had my AFR heads.
DRE rockers. Give them a call, you wont be disappointed. Price is competitive, all their rockers get all the goodies, and they will custom build/custom set them up for your heads.
www.dreracing.com
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
