KEYED CRANKSHAFT HUB for 95 Z28
Old Sep 4, 2006 | 04:50 PM
dutss707's Avatar
Smile KEYED CRANKSHAFT HUB for 95 Z28
Where can I buy above item, aside from Thunderracing, as they
have a $50 core charge. I would also like to know if anyone
knows, who produces these Keyed Crankshaft Hubs. Competitive pricing?
95Z28 LT1A4: Red w/Black Ttop: Racetronix fuel system: 58mm TB: full
race susp: BeCool Rad: Flex-a-lite Black Magic extreme Fan: Meziere etc.
etc....too much to list.
Old Sep 4, 2006 | 06:03 PM
OBE1 95Z28's Avatar
Re: KEYED CRANKSHAFT HUB for 95 Z28
Just in case you're not familar with a core charge...you get your $50 back when you ship them your original hub.
Old Sep 4, 2006 | 06:08 PM
gixxer92's Avatar
Call ATI performance tomorrow and see if they have them available, I never tried to see if either of my ATI damper hubs would mount to the GM part but they may, it's worth a try and you can order just the hub in steel or aluminium.
Old Sep 5, 2006 | 02:51 AM
The Engineer's Avatar
Jeg's has a keyed hub and SFI approved harmonic dampner for LTs (Jeg's own brand). Also, an under-drive option. You can buy the hub alone, or as a set with the dampner. I have both and they are very high quality. I really like having the hub keyed on the LTs.
http://www.cardomain.com/ride/2189634
Old Sep 5, 2006 | 05:45 PM
dutss707's Avatar
thanks for reply, however, hub you are describing is a Balancer Hub,
not a Crankshaft Hub (keyed)....
Old Sep 4, 2007 | 05:53 PM
What it the difference between the crankshaft hub and the damper (there is no balancer on an LT1) hub?
Old Sep 4, 2007 | 06:32 PM
pizzi-man's Avatar
The hub bolts to the crank and the damper bolts to the hub. I just looked at a lt1 crank from a carpice 350 and it has no key way for the damper assembly but the eagle crank in my 383 does. I picked up a harmonic damper assembly from professional products and it has a spacer kit with it to move the damper forward for the caprice 350 as opposed to the camero.
HectorM52
Jul 30, 2017 11:46 AM
Chevyguy358
Jan 28, 2015 08:04 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
1LEThumper
Jul 14, 2003 12:45 PM
