Just Replaced Crank Seal, found a problem, w/ pix..
Old Sep 26, 2007 | 05:34 PM
Sick97SS's Avatar
Crank seal itself was pretty easy to do..
Here's the how-to with plenty of pictures...
https://home.comcast.net/~nstama/crankseal.htm
But here's the problem.. oil oozing out both lower plugwires connecting to the opti. Now my leak sprayed oil everywhere under there but i didn't think it would get into the wires. i wasn't about to take the opti out, but i think if i did and took it apart i would find thats it's full of oil, like this guy...
http://web.camaross.com/forums/showthread.php?t=542931
Car runs great so im stumped. Time for an opti replacement??
Old Sep 26, 2007 | 07:56 PM
slowride94z's Avatar
I replaced the front crank seal about 2 months ago thinking it was slinging oil everywhere. not so. it appears to be something behind the opti. someone else may have first hand knowledge to help "us"
Old Sep 26, 2007 | 08:04 PM
Kevin Blown 95 TA's Avatar
I think it came from the crank seal - doubt its even possible for oil to ever get in the cap and run thru to the towers.. Spray it all out with WD-40 or something, put some dialectric grease on them and shove them back in there.
Old Sep 26, 2007 | 08:06 PM
Hybrid86Z's Avatar
i second this motion
Old Sep 27, 2007 | 12:13 AM
Jim D's Avatar
Power transformers are filled with oil so I don't think that oil in your opti would short anything out. Alhough I would think that if your opti were full of oil, the "optical" part of the "opti" wouldn't see very well...Just thinking...
Old Sep 27, 2007 | 12:48 AM
Tekprodave's Avatar
I would address the oil leaking first. There are three holes/seals on the timing cover. Oil can also come through the bolts that hold the opti. From the pics it looks like a lot of oil is leaking from somewhere. Probably multiple sources.
Old Sep 27, 2007 | 09:46 AM
raroz28's Avatar
Your water pump shaft seal is leaking.
If it were me, I would have replaced all the timing cover seals while the hub was off.
Old Sep 27, 2007 | 10:01 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I hate oil leaks.
Old Sep 27, 2007 | 10:12 AM
Tekprodave's Avatar
Originally Posted by BTC
I hate oil leaks.
LOL!! It's even worse on boosted setups. I'm beginning to think the LT1 is akin to a block of swiss. :/
Old Sep 27, 2007 | 01:12 PM
Sick97SS's Avatar
Well should i wait till i swap the opti to change all the seals.
i mean if im gonna have to take the WP off anyways, might as well change the opti to right?
If I am gonna change all my front seals what all do i need in terms of gaskets and seals?
Crankshaft seal - already replaced
optispark o-ring
water pump shaft seal + water pump gaskets (2)
timing cover gasket.
Old Sep 27, 2007 | 01:35 PM
BTC's Avatar
BTC
You can do it without taking off the timing cover, so you don't necessarily need a timing cover gasket. If you've already replaced the crank seal, and you know it's not leaking, you just need the water pump & opti seals, plus the water pump gaskets.
If I left off anything, someone will chime in.
Old Sep 27, 2007 | 01:42 PM
pizzi-man's Avatar
The oil in the picture appears to have a red tinge to it. It is possibly trans fluid or power steering fluid?
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
1LEThumper
Jul 14, 2003 12:45 PM
