Cooling problem in computer?
Old Sep 27, 2007 | 04:12 PM
rta6psd's Avatar
My 96 Lt1 is not kicking on the right side cooling fan. My mech checked it out and said I need a new computer because its not telling it to come on. He checked the relay as well. Does this sound correct? He also found a leak in the fuel line. Could that in any way be why I have a miss at idle only. Thanks
Old Sep 27, 2007 | 04:39 PM
Ok4thGen's Avatar
Do a search for Fan ByPass to fix your fan issues as replacing your pcm will be expensive and not a garuntee that it will fix it. I would almost bet the problem with your fans is somewhere else.
also a leak in a fuel line would be pretty massive as the pressure threw the system, i would definatly look into this yourself to verify the problem.
Old Sep 27, 2007 | 05:05 PM
BUBBA's Avatar
Obd11 Trouble Codes
P1641 Fan Control (fc) Relay 1 Control Circuit
P1642 " " 2 & 3 " "
Old Sep 27, 2007 | 05:10 PM
BUBBA's Avatar
Check Shoe's site at shbox.com (schematics/wiring) for fan crap.
Old Sep 27, 2007 | 05:16 PM
It is not impossible, but the computer rarely has a problem like that. It is also difficult when you have to rely one someone else to "tell" you that something in particular is wrong. Not that I don't trust mechanics (lol), but they can often tell you something that is not the whole truth.
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
ChrisFrez
Jan 18, 2015 08:05 AM
Absolute Z28
Jul 19, 2002 02:21 PM
