Just found out K&N filter was completely off tube!
Old Jun 16, 2007 | 09:45 PM
Whitey13's Avatar
Yeah, it was just sitting on the splash gaurd. I put it on when it was 30 below out and it must not have been tight enough for the 90 degree weather right now.
This is the intake I have: http://www.knfilters.com/search/prod...Prod=57-3010-1
Would this cause the car to run more poorly because the air/fuel mixture is off?
Old Jun 16, 2007 | 09:51 PM
km9v's Avatar
Your MAF is probably dirty. Was it running poorly? Did you throw any codes?
Old Jun 16, 2007 | 09:57 PM
Whitey13's Avatar
No codes, but yes it has been running rather poorly lately. Will throttle plate cleaner work for cleaning the MAF? I've been to 4 shops in town and that is all I can find.
Old Jun 16, 2007 | 10:05 PM
Whitey13's Avatar
I live 2 miles down a gravel road as well.
Old Jun 17, 2007 | 12:43 AM
hotrod18_69's Avatar
Get some electrical clean from autozone, don't use crab, throttle, or brake cleaner. It can hurt the sensor..
My filter use to fall off all the time too.. Now whenever i clean it and put it back on, i just put alittle super glue between the filter and the tube once its on... It'll stay there untill you twist it off the next time you clean it..
Old Jun 17, 2007 | 11:16 AM
Whitey13's Avatar
Ok, I'll get some electrical clean then. Super glue sounds like a great idea. Thanks!
Old Jun 17, 2007 | 02:20 PM
klrz28's Avatar
how long was it off for? lots of miles ?
Old Jun 17, 2007 | 02:33 PM
Pandamonkey's Avatar
Just clean the intake, MAF and throttle body, and do a fresh oil change.
You'll be fine.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alphaauto
Feb 5, 2015 05:25 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
HuJass
18
Jun 24, 2002 09:19 PM
