Jet hot LT questions
Old Feb 28, 2006 | 08:17 PM
chevyman502bb's Avatar
soon im going to order some jet hot LT headers and ORY to go along with a catback (dont know which yet).
first off with LTs will i need O2 extensions?
is the Y pipe linked below made to fit both single cat and dual cat style catbacks?
how often do people burn plug wires with Jet hots?
how long does the coating last?
how many of you welded flanges to the headers instead of using the slip fit?
http://www.ws6project.com/user_stor/...7f92562ebf203b
im sure ill think of more questions but for now this will suffice. any and all input is appreciated
-Jon
Old Feb 28, 2006 | 08:33 PM
2000GTP's Avatar
Re: Jet hot LT questions
-Jon
You will need some extensions for the long tubes, 12" extensions will do the trick. The y-pipe will work with both catback setups. As for the coating, it is a hit or miss. Some people have had it last for many years without incident and others complain of rust starting in just a matter of months. Many people flange their headers and y-pipe, it makes disassembly easy in the future but has some slight drawbacks which include the possibility of flange leaks and reduced ground clearance.
LT14LIFE
Feb 9, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
RedLineRev
Jan 23, 2003 03:51 PM
ferraricameron
Jul 29, 2002 07:46 PM
