Jacking up the motor ?
Old May 8, 2008 | 05:55 PM
MTBSully's Avatar
I undid the 3 bolts on each side removing the block from the motor mount, and i think i am ready to jack up the motor. But i am replacing my oil pan, so i can't jack from there. Should i jack from the harmonic balancer? Is there a limit to how high i can jack the motor? Obviously the intake on the firewall but will i harm the engine or tranny at all if i jack it up all the way?
Old May 8, 2008 | 06:03 PM
caldercay's Avatar
First off - I hope you haven't removed the bolts from BOTH
motor mounts, right? You should be doing one at a time.
I've always used a 2x8 (about 6-8" long) on top of a floor jack, just
under the side of the pan to be jacked up.
Old May 8, 2008 | 06:27 PM
Pontiac_97's Avatar
whats wrong with removing both motor mount bolts? hes replacing the pan. hes gonna have to un-do them to get the engine high enough to replace the pan
you can take a piece of wood like 8-10 inches long and jack from the bottom of the timing chain cover. puts less stress on the crankshaft. just jack it up until it doesnt go up anymore. it may also help to loosen the trans mount bolt so the engine/tranny can flex a little
Victor Lamb
Aug 26, 2017 02:52 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
BigWil
Mar 29, 2015 12:24 PM
rick350
Mar 16, 2015 02:59 PM
JasonD
Aug 16, 2002 11:52 AM
