ac delco vs. generic?
Old May 7, 2008 | 09:26 PM
94z28lt1black's Avatar
Question ac delco vs. generic?
okay, i have been wondering something for a little while... is it really worth the money to spend so much on gm oem (or ac delco) over generic parts like borg warner or other cheaper brands? i understand for the most part that "you get what you pay for" but is this always the case? are gm oem or ac delco parts really worth that much more than other brands or is it that you pay more for them because of the name on the parts? i ask this because i may be looking at replacing my entire ignition system and through price quoting i have noticed a significant difference in the price totals when comparing all ac delco to all generic... most of the people i have talked to in person say that yes ac delco is worth the money and two of them told me the would kick my butt if i didnt go with all ac delco. however, they all work in shops and stores that sell the parts... are they being honest or just trying to make some extra bucks? so if anyone could shed some light on this subject i would greatly appreciate it!
Old May 7, 2008 | 09:52 PM
KajunKadillac's Avatar
AC Delco OE Platinum plugs are good, but i believe a good amount of people here run NGK TR55, and NGK TR55IX plugs here too. I originally bought some bosch plugs but after hearing stories about them in chevy blocks, i quickly returned them and got some AC-Delco plugs. If you want to play it safe, get the OE plugs.
Old May 7, 2008 | 11:23 PM
1989TransAm's Avatar
Depends on the part. Something like the fuel pump I always go AC Delco.
Old May 8, 2008 | 12:48 AM
mrmint69's Avatar
O2 sensors are a must when it comes to Ac Delco. Other sensors are important but not as much so.
Old May 8, 2008 | 02:37 AM
Dadic 78's Avatar
I would recommend sticking with AC Delco parts... I learned my lesson last week with a cheap reman opti core and MSD Cap/Rotor.
Save some frustration, and do it right the first time.
Old May 8, 2008 | 05:39 AM
maverickmk's Avatar
/\/\/\ that picture right there is worth a thousand threads regarding AC Delco vs other brands of opti sparks
Old May 8, 2008 | 06:57 AM
2000GTP's Avatar
It seems like some parts such as the opti and 02 sensors are the best bet for Delco replacement only versus the generic brands.
Old May 8, 2008 | 07:11 AM
sl2racer's Avatar
that picture shows a bit of clearance issues. haha
Old May 8, 2008 | 11:54 AM
what about with permormance motors? i eventually plan on rebuilding my stock lt1 and building it into a 383 stroker with lt4 heads, lunati voodoo cam and lunati sledgehammer crank... can the ac delco parts handle the permormance demands better than other "performance parts" like the opti, injectors, coil, and other things im just not thinking of right now?
Old May 8, 2008 | 12:24 PM
ss.slp.ls1's Avatar
My JEG's brand opti failed after just two weeks, rotor detached. Put in a brand new AC Delco, been problem free ever since.
Old May 8, 2008 | 12:39 PM
Thumbs up
well, i've always had faith in gm parts, i just dont like the mark up for them but, i will stay faithfull and spend the extra money... especially if it will cause me less headache in the long run... thanks!
Old May 8, 2008 | 05:24 PM
Dadic 78's Avatar
Yeah, just a hint! The dowel-gear that came installed (and was non-removable) in the reman core was too long. Upon assembling cap to core, there were no contact issues, but when bolted to the motor... Well, the evidence is in the pic!
FYI, I got 40 miles out of it until it eventually crapped out. So, it's a good way to save money if you don't plan on driving the car more than 40 miles... EVER...
Old May 8, 2008 | 05:35 PM
caldercay's Avatar
AC Delco.
Old May 8, 2008 | 07:02 PM
ss.slp.ls1's Avatar
Opti and coil should be no problem, but depending on how much power you plan to make, you will likely have to upgrade the injectors.
magman
Apr 15, 2016 03:08 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
