Jacking up the motor ?
I undid the 3 bolts on each side removing the block from the motor mount, and i think i am ready to jack up the motor. But i am replacing my oil pan, so i can't jack from there. Should i jack from the harmonic balancer? Is there a limit to how high i can jack the motor? Obviously the intake on the firewall but will i harm the engine or tranny at all if i jack it up all the way?
motor mounts, right? You should be doing one at a time.
I've always used a 2x8 (about 6-8" long) on top of a floor jack, just
under the side of the pan to be jacked up.
you can take a piece of wood like 8-10 inches long and jack from the bottom of the timing chain cover. puts less stress on the crankshaft. just jack it up until it doesnt go up anymore. it may also help to loosen the trans mount bolt so the engine/tranny can flex a little
Victor Lamb
Aug 26, 2017 02:52 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
