Internally balanced 355 LT1 what flexplate to use
Old Mar 18, 2003 | 11:19 AM
dr97z's Avatar
Hey guys,
I'm in the process of getting my rotating assembly balanced, and I bought a new forged Eagle crank, my machinist said it was set up to be internally balanced. Will a regular neutrally balanced 350 flexplate work? I just ordered an SFI aproved 153 tooth neutrally balanced flexplate from Jegs and was wondering if it will bolt up alright. Thanks.
Old Mar 18, 2003 | 06:40 PM
Brandy's Avatar
My Jegster flex plate is for externally balanced. Most of the aftermarket ones are internal though for whatever reason. If it has the weight welded on it then it's externally balanced.
Old Mar 18, 2003 | 09:30 PM
rskrause's Avatar
Moderator
Depends if it has the correct small bolt circle to fit the flange on your crank.
Rich Krause
Old Mar 19, 2003 | 06:19 AM
Since this is an "LT1" specific thread, let's move it to LT1 Tech.....
Nostang 96z
Sep 15, 2002 10:15 PM
Nostang 96z
Sep 14, 2002 08:22 PM
Nostang 96z
Sep 10, 2002 08:54 PM
Nostang 96z
Aug 31, 2002 12:01 PM
