Intake manifold: what are these?
Old Nov 15, 2009 | 07:37 AM
Future_Z_Owner's Avatar
Im buttoning the car up now and ive got the HVAC and EVAP ports on the passenger side all hooked up but the driver side is the one thats baffling me. What are these 2 ports for? I have deleted my EGR and AIR just incase thats what these are for. Thanks in advance!
Old Nov 15, 2009 | 08:25 AM
wayneg1035's Avatar
the big one i believe is for the brake booster, and the small one on my car connects to my opti and egr or fuel pressure regulator on back of manifold. I cant double check because my car is not here. 94 normally doesn't have a vacuum line to hook up to the opti, but i am running an MSD opti which has the vacuum hookup.
Old Nov 15, 2009 | 08:53 AM
Thank you for the response. The fuel pressure regulator is on the passenger side and like you said 93-94 does not have an opti breather. So i guess EGR? I like the color you painted your intake. Its different but still looks good.
Old Nov 15, 2009 | 10:03 AM
When you have a question like this, Shoebox usually has the answer (recognizing that most of his pictures are for a 95):
http://shbox.com/1/opti_vacuum_conn.jpg
http://shbox.com/1/4th_gen_tech1.html
On your 94, the PCV vacuum comes from the connection labeled for the Opti vent.
The EVAP connection is on the throttle body, not the intake manifold. The two vacuum nipples on the passenger side toward the rear are for the HVAC and the fuel pressure regulator.
Old Nov 15, 2009 | 10:44 AM
Thanks Injuneer
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
Countryboychevy
Jun 13, 2015 02:49 PM
maybe2fast
Mar 26, 2015 08:34 AM
