Intake manifold question
Old Nov 24, 2007 | 12:29 AM
95z28man's Avatar
How important is the little shield-type thing that is bolted to the bottom of the manifold?? Quick answer will be VERY apppreciated.
Old Nov 24, 2007 | 01:14 AM
speed_demon24's Avatar
Without it you will be sucking in ALOT of oil through the pcv valve, so very important.
Old Nov 24, 2007 | 01:27 AM
95z28man's Avatar
Damn, not what I was hoping to hear. I just bolted up my new manifold without swapping the old one on first... I'm assuming that bad things will happen if I don't take it off and put the cover on?
Old Nov 24, 2007 | 01:56 AM
Probably foul your plugs, 02's, carbon up your pistons and heads, ect. Or you could just cap off your PCV system and run breathers, but thats not good for your oil since it will leave all the contaminants in the crankcase which will go into the oil.
Old Nov 24, 2007 | 06:42 AM
SS RRR's Avatar
It's a baffle for your PCV system and as already stated could introduce a fairly large quantity of oil into the combustion process.
Old Nov 24, 2007 | 09:46 AM
95z28man's Avatar
Well, I successfully failed at taking my old one off. All I did was strip the dumb bolts. Can I order a new one with the hardware? I don't even know what the thing is called. Any help?
Old Nov 24, 2007 | 10:11 AM
Also prevents hot oil from collecting on the bottom of the manifold, and heating up the incoming air.
Old Nov 24, 2007 | 01:36 PM
95z28man's Avatar
Anybody? Will I have to get a new one from the dealer? What else can I do?
Old Nov 24, 2007 | 03:17 PM
95z28man's Avatar
Got the old baffle off. Problem solved.
Noer
Feb 28, 2015 11:29 AM
CARiD
Jan 27, 2015 06:27 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
