Intake manifold to head port sealing question?
Old Jun 10, 2007 | 03:00 PM
12SCNDZ's Avatar
OK. I've seen a few threads lately about this subject. Apparently, many have issues with the intake gaskets not sealing if the heads and/or block have been cut. Is there any way to check this upon initial assembly? My block has been zero decked, but the heads have only a light cut on them. I'm using Cometic .036" head gaskets, and GM intake gaskets. The intake bolt holes all line up, and the end gaps look about normal.
Frank
CPT
Old Jun 10, 2007 | 04:01 PM
Fastbird93's Avatar
The intake bolt holes lining up is a GOOD thing. To check it, take a pair of paper gaskets and using those, torque the manifold down. Then remove and check for a good pinch. It will be readily apparent if you're not getting a good pinch somewhere.
Old Jun 10, 2007 | 07:50 PM
12SCNDZ's Avatar
wow...I kinda thought I'd get a little more input with this. Especially since it seems so common.
Frank
CPT
Old Jun 10, 2007 | 09:23 PM
mdacton's Avatar
I have never really had a problem.....I keep an old set of gaskets to check with first. But no problem up to this point
Killer94z
Jan 13, 2015 12:06 PM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
