intake elbow question
Ok, so if you upgrade to the 1LE, I keep seeing people on this board talking about a "donkey dong." What is this? Also i c people talkin about a removed silencer, what do you have to do to do all this?
Can someone explain to me what all of this means?
I need to get a new intake elbow, but im not sure what to get.
But what do you do with that donkey dong? I have heard of people plugging it or removing it all together...I just dont know that much about it. Just wondering if i can get one on this board cheaper.
I saw the trick flow one on summitt, but just thought i would try here first to see if anybody has a used one around.
well the donkey dong(silencer) is attatched to the elbow. so you can remove it and plug it, or but a new elbow. Ive heard of people plugging it with pert plus shampoo bottle tops. I just bought a new elbow because mine was beat to hell.
http://shbox.com/1/elbow_bottom.jpg
Here is the 1LE elbow, notice that there is no hole where the "donkey *******" was. This part is approx. $47.
Stock Elbow - Has donkey scholong at the bottom of the elbow extending down a bit over a foot. You can plug it if you want. Rubber.
1LE Elbow - Same as stock elbow except it doesnt have the ******* thing part. No need to plug it because theres no hole or anything for it. Rubber.
Aftermarket elbows - Same as 1LE, except they look kinda nicer but some would argue that the extra heat they soak may have a small affect on HP.
1995-1997 1LE intake elbow
(for vented opti) 25147187
no you wont have to plug this.
Originally posted by tfs95z28
is that the 1LE? It says it has a silencer, so do i have to plug that up myself?
slothgrant
Aug 22, 2002 03:01 PM
turbo_Z
Aug 19, 2002 10:50 PM
30thZ286speed
Aug 3, 2002 04:54 AM
