Intake ????
Old Dec 2, 2006 | 02:57 PM
95zsean's Avatar
Intake ????
I's there a differance between a 93-97 intakes for a LT1? Or they all the same?
Old Dec 2, 2006 | 03:01 PM
SC/TA's Avatar
I think 93 and 94 are different than 95 and up. The early models didn't have the cross-over pipe for the fuel rails.
Old Dec 2, 2006 | 03:04 PM
formulalt4383's Avatar
93 is different. 94 uses the same intake manifold as the later models but a few different vacuum fittings due to the opti vent and different route of the PCV valve.
Old Dec 2, 2006 | 03:07 PM
95zsean's Avatar
I'm look into buying one that the guy says is for a 96-97,will it fit my 95?
Old Dec 2, 2006 | 03:09 PM
Should fit fine.
Old Dec 2, 2006 | 04:58 PM
Mikek340's Avatar
Yes it will work fine just be aware of a 93. 94-97 will all work on your setup.
Old Dec 2, 2006 | 07:31 PM
Jlo's Avatar
Jlo
I hear the 94-95 have intake port shaped different better for porting.
Old Dec 2, 2006 | 09:19 PM
95zsean's Avatar
Thanks!!! I will keep mine just in case I decide to do a Engine build.
Old Dec 2, 2006 | 10:12 PM
My Red 93Z-28's Avatar
The crossover is in the back behind the manifold, instead of cast into the manifold behind the TB in the 93s.
Although, I used my 93 fuel rails on my LT4 manifold and just turned them 180* so that the crossover was in front. The 93 rails are a hair wider at the crossover than the later models though.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
Countryboychevy
Jun 13, 2015 02:49 PM
maybe2fast
Mar 26, 2015 08:34 AM
