inspection test ?
Old Oct 31, 2006 | 11:35 AM
davidc212k's Avatar
inspection test ?
i just took my 1995 camaro z28 to the take the inspection. It failed.
They told me something was wrong with the A/C. He said that in most times it was caused from catalytic converter and i told him that it use to work, until i started to change the spark plugs off one day and some a spark came out and after that it stoped working. i also had the Compressor changed. (new). and he still said it was the catalytic converter. so i thaught to myself could that be the reason. so people please give me some tips or reason what might be wrong.
Old Oct 31, 2006 | 11:46 AM
ulakovic22's Avatar
I don't see how. Why does it matter if your A/C doesn't work, it has no bearing on your emissions. Only thing I can think of is that he meant AIR pump and not A/C. If you're AIR pump is out then it won't pump fresh air into the cat to heat it up. Either way I don't understand how a new cat would solve the problem. Probably trying to get money out of you, take it somewhere else.
Old Oct 31, 2006 | 11:50 AM
davidc212k's Avatar
thats exactly what i thaught someone would say.
he just wanted to get money from me and i cant take it somewhere else becuase i have 15 days to fix that problem and then take it again to the same place becuase they already charged me 40 bux.
Old Oct 31, 2006 | 11:51 AM
davidc212k's Avatar
well i just read the inspection papers again and its my bad.
it says the HC Failed. what is the HC ?
Old Oct 31, 2006 | 12:10 PM
The means there was excessive unburned hydrocarbons (HC = gasoline) coming out of the tailpipe. Could be a bad cat, could be running excessively rich, could be a leaking injector, could be misfiring. How did it do on CO and NOx?
Old Oct 31, 2006 | 04:41 PM
Heatmaker's Avatar
Advanced Member
I"ll tell you, nothing fixing an HC issue, like a few 20's taped under the bumper.
Old Nov 2, 2006 | 04:07 PM
davidc212k's Avatar
im a nub with cars. what do u mean with a few 20's taped under the bumper ?
Old Nov 2, 2006 | 04:10 PM
2000GTP's Avatar
He's hinting that you make a bribe, but he's joking( I think ). Definitely something I wouldn't try, you can get in pretty big trouble.
Old Nov 2, 2006 | 04:14 PM
davidc212k's Avatar
i get him now, lol
well i already got a new catalytic converter on it.
are the tips suppose to be dropping some sort of liquid ?
Old Nov 2, 2006 | 04:17 PM
2000GTP's Avatar
i get him now, lol
Its just water. Very normal.
Old Nov 2, 2006 | 05:55 PM
davidc212k's Avatar
w0w thx
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
karpetcm
Aug 14, 2015 03:02 PM
asilomar244
Jul 12, 2015 05:53 AM
ducttape1975
Jul 10, 2015 06:29 PM
