Inline fuel pump with stock one still installed?
Old Apr 25, 2005 | 08:06 PM
maksik7's Avatar
I have problems with my stock fuel pump, it whines loudly and leaks fuel pressure. I wanted to change to an aftermarket pump, but dont feel like dropping my tank or cutting up my car. If I bought an inline fuel pump, could I set it up so it will work with my old pump still on the car? Has anybody done this, or have a link to a guide?
Max
Old Apr 26, 2005 | 10:47 PM
maksik7's Avatar
Re: Inline fuel pump with stock one still installed?
Doesn't anyone know if this works or not?
Old Apr 26, 2005 | 11:08 PM
97LT1Boy's Avatar
I'm not a genius on these cars, but from simple automotive knowledge that isn't going to help. If anything, it will probably hurt the factory fuel pump and result in failure of fuel delivery and lead to hurting something else. You can't use a pump to pull fuel from another pump, you'll run out somewhere in between eventually.
Old Apr 27, 2005 | 09:46 AM
OBE1 95Z28's Avatar
In-line pumps are commonly used with initial supercharger and nitrous kits. They can supply fuel under high pressure demands (i.e. 80 psi needed for FMUs) that the stock fuel pump can't deliver. But I don't think they'll solve you issue with a dying stock pump. I suggest you drop the tank and solve the problem properly.
Old Apr 28, 2005 | 01:08 AM
fredmr39's Avatar
What are you going to do when your stock pump dies completely? Then how will your in-line pump get any fuel to pump?
Old Apr 28, 2005 | 02:29 AM
maksik7's Avatar
Maybe I asked the question wrong. I want to cut power to the stocker and mount an inline in a more accesible place. My question is can I somehow leave the stock pump in an "open" position so fuel could flow freely though it, and be pumped by the inline?
Max
Old Apr 28, 2005 | 09:32 AM
You can not leave a "non-operating" stock pump in the system, and expect the inline pump to pull fuel through it. It will act like a big blockage (there is no "open" position). That drops the pressure to the inlet of the inline pump, and if you drop the pressure low enough, the fuel will vaporize and you will get little in the way of flow out of the system.
Old Apr 28, 2005 | 09:01 PM
MarkyMark's Avatar
http://web.camaross.com/forums/showthread.php?t=340701
Read that thread man, I think it will help you out big time.
Old May 2, 2005 | 05:29 PM
maksik7's Avatar
Thanks for the advice guys. I figured it wouldn't work, but it doesn't hurt to ask. I guess I'll just have to change the fuel pump like everyone else when it finally dies.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
